z06 wheels on a third gen camaro
Old Feb 7, 2007 | 12:27 PM
Jared87Z28's Avatar
Car: 87 Z28, 81 GMC Sierra, '00 Z28
Engine: 305 TPI, Carbed 355 Trickflow, LS1
Transmission: 700R4, TH-350, T-56
Axle/Gears: 2.73, 3.08, 3.42
does anybody have any pics of a third gen camaro with a set of C5 z06 wheels? any color, any size. im lookin at buying a set of 18inch polished ones but i cant picture them on the car or even know if they will fit right.
Old Feb 7, 2007 | 02:16 PM
simz28's Avatar
Car: 92 z28, 07 Silverado
Engine: LS1, 5.3
Axle/Gears: 3.73, 3.23
check my garage out, there chrome 18x9.5 all the way around
Old Feb 7, 2007 | 05:42 PM
Jared87Z28's Avatar
what is the backspacing on your wheels?
Old Feb 7, 2007 | 05:45 PM
simz28's Avatar
Engine: LS1, 5.3
The backspacing is stock, and i have 1.5 inch spacers
Old Feb 7, 2007 | 05:50 PM
Jared87Z28's Avatar
did you have to do any kind of modifications to get them to fit, other than the spacers?
Old Feb 14, 2007 | 02:53 AM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i have a set of z06 wheels in 18x9.5 front and 18x10.5 rears. i have ls1 brakes, and a 1.5 inch spacer on the front. i have a fourth gen rear in my car. i have not fitted the rear wheels yet, but i plan to on thursday. i figure ill need around a 1/4 inch spacer to get them to sit where i want them under the car.
Old Feb 14, 2007 | 06:27 AM
Jared87Z28's Avatar
post some pics after you get them on if you would.
Old Feb 14, 2007 | 09:42 AM
simz28's Avatar
Engine: LS1, 5.3
Nope, i didnt have to do anything else to them, and i also have the ls1 fronts and i have the ILE PBR rears, and i love it, stops awesome.
Old Feb 17, 2007 | 05:57 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Here is my car wearing 18" by 9.5 polished Z06's. I also have C5 brakes up front too. Right now the car has the stock springs in it. Putting in a pro kit soon.
Old Feb 17, 2007 | 09:55 AM
skater_nater86's Avatar
Car: 1992 camaro Z28
Engine: 305 tpi
Axle/Gears: 3.42 4th gen posi
RandyZ28, Just wondering do you have any rubbing issues with that size rim? any modification? The car looks really nice tho! thanks
Old Feb 17, 2007 | 12:31 PM
cabech984's Avatar
Car: 1990 Firebird
Engine: 6.0L LQ4
Transmission: 4L60E 4000 Stall
Axle/Gears: 3.23 G80 (01 TA)
Mine isnt a Camaro, but I think you'll get the point. I have an 4th gen rear axle & 2" adapters up front!! Click the link.
https://www.thirdgen.org/forums/atta...icture-044.jpg
Old Feb 17, 2007 | 06:34 PM
Randy92Z's Avatar
Engine: Miniram 383
No rubbing at all, Im using 1.7 spacers up front and a 4th gen rear.
Old Feb 17, 2007 | 08:46 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
Heres mine. I have a slight rubbing issue that I havnt been able to fix yet buy they are 17" x 9.5
Old Feb 17, 2007 | 09:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I'd reccomend some aftermarket shocks with that too. I replaced my stockers with some OEMs, and then put on the ProKit. The springs killed the Monroes in about 6 months.
Old Feb 18, 2007 | 04:40 AM
Randy92Z's Avatar
Engine: Miniram 383
I have some TPIS aftermarket shocks and struts in there now. I think TPIS calls them there "super shocks and stuts"? There suppost to be some re-valved Corvette shocks that help improve your laptimes on the track.
Im also gonna get a pro kit and lower the car a bit. But Im putting in Hooker 2210 longtubes and want to wait till there in before I lower it and lose too much ground clearance.
Old Feb 18, 2007 | 04:46 AM
Randy92Z's Avatar
Engine: Miniram 383
What front spacers and brakes are you running? When I had my old 2.25" spacers on up front I had a few rubbing issues as well. When I upgraded to the C5 front brakes the rotor hat thickness was .3, so that spaced them out even further. I had some smaller spacers made, 1.7 now everything is perfect!
I see your front wheels stick out quite a bit, I remember that on mine.
Old Feb 18, 2007 | 08:36 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Transmission: 4L60
Im running LS1 front brakes with 2" spacers. Maybe I need to get 1.7 ones. Even my stock tires rubbed a little after I put spohn front a arms on. I willl be getting there K member when I pull the engine.
Old Feb 20, 2007 | 12:36 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I am running 17X9.5's all the way around, I have a 4th gen rear and it didnt require any spacers out back. thats with 315 Nitto DR's in the back. Although the bumpstop needs worked. In the front I have C5 Z06 brakes, with a 2" spacer. since the brake conversion spaces the wheel out ~.3-.4" 1.6-1.7" spacers would make it tuck really nice, but right now its not terrible, they still tuck under the fender, barely. The rear is **** though! sorry you cant tell from the pics, wrong angle and low quality (camera phone). This was with no motor, and a fresh sportline kit. The car has settled much better in the front.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
I'llrocya
Feb 2, 2016 11:43 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
