Enlighten me!
Old Apr 4, 2007 | 05:21 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Transmission: manual
Enlighten me!
HELLO im getting used to thirdgen by now and found alot of useful information. i have an 89 rs 305 tbi wit some suggestion easy mods and now i heard that suspension can help alot. im a motor head and never tinkered wit suspension but i was told i have aftermarket air shocks in the back?? what are the things i would need to replace and/or upgrade inorder to keep it simple, cheap, and helpful? any help will be considered honored
thanks
blimko
Old Apr 4, 2007 | 05:35 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Enlighten me!
1st no matter what, no matter what brand, get Subframe connectors and a wonder bar.
I upgraded to 36mm front sway bar and 24mm rear sway bar.
And I just purchased Lower Control arms and a panhard bar from UMI.
I also suggest replacing the shocks and struts, I went with Koni Yellows, but they might be overkill for you, depends on what you wanna do.
Old Apr 4, 2007 | 05:37 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Enlighten me!
how to i go about getting ahold of these and exaclty where are they located and do you know base prices? sorry if to many questions but i gotta learn somewhere..considering my future engine ideas your version of overkill will probably be rephrased as underkill.
not trying to be cocky
thanks
blimko
Old Apr 4, 2007 | 05:42 PM
krisb410's Avatar
Re: Enlighten me!
I got some of my stuff from the junk yard or from the classified section here.
Also check out the board sponsers: UMI, Spohn, and TDS.
Old Apr 4, 2007 | 05:48 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Enlighten me!
how did you get this out of a junkyard? isnt it all aftermarket?
Old Apr 4, 2007 | 05:51 PM
krisb410's Avatar
Re: Enlighten me!
Wonderbar and sways can be found in the junkyard
Old Apr 4, 2007 | 06:02 PM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Enlighten me!
from what cars do i look for this off of?
Old Apr 4, 2007 | 06:46 PM
krisb410's Avatar
Re: Enlighten me!
Wonderbars were only available on IROCs, but a lot of people added them to there cars. The best way is to measure the sways on the car, but they were on most Iroc's, Z28's and all WS6 Pontiac's.
Old Apr 4, 2007 | 07:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Enlighten me!
A kit of poly bushings is fairly cheap, and will drastically increase the handling of the car. Along with a set of SFC's and it'll feel like a race car. (assuming your springs and shocks are still good... if not, $1000 grand total and it will feel like a race car - compared to stock).
I wouldn't count on finding a good sway bar or wonderbar in the JY, unless you're really lucky. A wonderbar is about $60 from Spohn I think. Sway bars are around $140 I think, and probably come with the frame bushings. Throw in the endlink bushings for $20 and you're set.
Old Apr 5, 2007 | 11:50 PM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
Re: Enlighten me!
How much money do you have to spend??
Old Apr 6, 2007 | 09:32 AM
blimko's Avatar
Car: Camaro RS
Engine: 305 tbi
Re: Enlighten me!
im on a short budget right now but start my new fulltime monday weekends off!! you know what that means..work all week and build a sweet azz car on weekends. i need to know where this stuff is located on the car because im an idiot when it comes to this stuff. like i said, motor guy not suspension
Old Apr 6, 2007 | 05:11 PM
krisb410's Avatar
Re: Enlighten me!
I see them all the time in the Junk yards, I guess I should start pulling them off and selling them for a profit. Sway bars are $12 and a wonderbar is $10 at the yards around here.
tmellott89
Oct 14, 2015 02:06 PM
91banditt2
Jun 19, 2002 12:04 PM
ChevyLuva3
Carburetors
Oct 19, 2001 01:14 PM
shaocaholica
Aug 4, 2001 07:41 PM
jimmyz83
Jun 22, 2001 03:08 PM
