View Poll Results: do you like or dislike...
Like the way it looks....
33.33%
Dont like the way it looks...
66.67%
Voters: 15. You may not vote on this poll
Got my new tires today....
Car: 72 Malibu, 89 RS & 04 Z71 extended
Engine: (2)350's & 327
Transmission: auto/T5
Axle/Gears: 4:11, 2:73 & 3:73
Re: Got my new tires today....
It would look better with stock 16 inch formula wheel or upgrade to 17's.
Car: 82 Trans AM
Transmission: th350 turbo
traction is great. little to no wheel spin at all and they hook great!! i need the wide tread pattern because i plan to auto-x the car and take it down the strip a few times here and there with the built single turbo 350 im currently working on. also the rims are ten inches wide. i have ten inches of tread hitting the ground in back and 9 in front.
and stock rims are just not my thing. they gotta be aftermarket!!
I doubt they will hook with a turbo'd 350. Plus you'd want less sidewall for autocross. The car will be all over the place with regular street tires.
Car: '89 Iroc Camaro
Engine: 5.7 350 TPI
Transmission: 700R4 Automatic
you asked for people's opions. I gave mine. Sorry if you don't like it.
Car: '83 Z28
You fit a 265 tire on the front? wow. I had problems with a 245/60 on my '83. had to go to a 235/60 and it doesn't rub
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I love the style. But yea, very wide on the front, don't plan on doing any parallel parking or... turning in a tight circle.
Those deep dish wheels and fat tires are great. Are those Cobra tires pretty good as far as traction? They're more of a street tire right? Harder longer lasting compound?
Car: 82 Trans AM
I have the cooper cobras with 245-60-r15 out back and 215-65-r15 in the front I believe. The rears are wearing great and I think they have great traction. The front holds great in turns, but they are wearing kinda quick. After about 3000 miles the outside grip on the front tires only has a 1/16 to an 1/8 left. Wearing kinda faster then expected, they are rated at 50000 miles. I think they must be a really soft rubber to be wearing that fast.
1 15" wheels and you can't turn tight? - you won't be doing much autocross
2 they're not gonna hook much power
3 you can't mini-tub these cars w/o "back-halfing" the car
It takes A LOT more than a turbo motor to go fast and handle well.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
