Help Quick!! Installing new tie rods etc - nut just spinning.
Old Apr 8, 2007 | 04:57 PM
Dr G's Avatar
Hi guys,
Might be making a silly mistake here but I'm not sure what I'm missing.
I'm installing new inner/outer tie rods and Spohns adjusters. When I go to tighten the nut it just spins the assembly. Is there a trick to hold them in position and stop them spinning whilst tightening the nuts?
Any quick replies would be much appreciated.
Thanks.
Old Apr 8, 2007 | 05:11 PM
Dr G's Avatar
Re: Help Quick!! Installing new tie rods etc - nut just spinning.
Never mind - got it sorted!
Ran the wire locking nut down and it seemed to work fine.
Old Apr 14, 2007 | 03:23 AM
Dr G's Avatar
Here's a picture of them beside the old ones off the car, if anyones's interested.
Attached Thumbnails Help Quick!! Installing new tie rods etc - nut just spinning.-spohn-tie-rods-adjusters
Old Apr 16, 2007 | 08:53 PM
JamFitz's Avatar
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Transmission: 3.27 auto: stock gear box
Axle/Gears: Stock
If anyone has this problem in the future I can only assume that the thread on the wirelock nut is tapered, and when putting on a different one as a dry-setup on the bench it was locking down on the thread and causing a higher torque on the ball joint than it can withstand.
On that note, make sure you get the wirelock on there properly since you cant really lock it down nice and hard, so get the torque wrench out.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
theurge
Aug 21, 2015 12:46 PM
crazynights
Aug 21, 2015 06:53 AM
TheJoeY88
Aug 13, 2015 06:51 PM
