Installation 101 for Dummys on STB/strut brace bar...
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
Someone was kind enough to sell me a Hotchkis strut bar brace. I got all my suspension parts powdercoated the same blue color, but now am stumped about installation of that strut bar. I assumed it attatched to the bolts on the strut towers, figured out quickly that was a mistake, ran through old forum notes for two hours, looked at photo in our albums.
What exactly is the proper method to bolt these units onto our cars??
Do I need a certain grade of fastner with this project?
And as a side question: are there better/worse brands of replacement 'Wonderbars' for our Camaro's??? Mine's an 88 IROC that I'm setting up for backroad rally driving; some legal some not....
Sincerely open to suggestions.
Nitro-Nicky
Nitro-Nicky
Re: Installation 101 for Dummys on STB/strut brace bar...
Check picture and use grade '5" hardware. The steering box support (wonder bar) on your car will work just fine.
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
[QUOTE=hgffrank;3366916]Man are you serious, I could spit a gubber bigger than that pic. How we gonna see it when its so small.[/QUOTE
You enlarge it ......
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if it helps better then the pic, you need to center in up, side to side on the flat part of the strut towers ahead of the strut. keep it away enough that it does not get in the way of the adjustment of the strut mounts. mark and drill holes, and bolt it together. for the extra 5 cents might as well go with grade 8 fasteners, no sense using weaker parts and possible breaking one. and use a good sized washer on the underside of the strut mount and just beware of the triangular piece that is under the strut mount, dont drill a hole through it.
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Just click on the thumbnail pic to enlarge it. After you click it though the picture is still pretty small.
Installing the STB is easy. You have to drill the holes to mount it. I would use some grade 8 hardware.
EXCELLENT PIC'S!!!!!! I understand now, just wasn't initially clear. Thanks a heck of a lot! Nitro
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Now that you are good to go on install...how can I get lucky enough to buy a Hotchkis STB?!?! Thats the only one Ill install on my car. And I just cant seem to find one to grab up.
You are lucky!
J.
You are lucky!
J.
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
Give Hotchkiss a call. Part # 2001SS, gun metal gray with red decals. Works with TPI only. $196.82. 877-4NO-Roll ext. 226
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
NBrehm
Aug 5, 2015 07:57 PM
