Where to buy Adj. Spherical Rod Ends
Car: 86 z28
Title pretty much says it all, I wanted some to make a torque arm and a steering brace, just couldnt find a web site to purchase the adjustable spherical rod ends from.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Where to buy Adj. Spherical Rod Ends
im not sure what an adjustable rod end is, but you can buy the rod ends from summit/jegs. i dont know about the tubing adapters
Car: 86 z28
well those are kinda what i was talking about only I was looking for wider ones. If you look at ones on umi and sphon LCAs they are wider. Or are they just using a two piece rod end with a bushing. How would you stop the rod end fom sliding left to right on the bushing?
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I git all of my stuff from Murf McKinney race cars. They have everything in stock and never had any issues with their products.
http://www.mckinneycorp.com/
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
check out aviation parts suppliers . [ the price will kill you ] but almost all of the different sizes can be found at a price . LOL .
UNCLE TOM
UNCLE TOM
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
they don't come "wider" you put in aluminum spacers on either side of LCAs for instance to take up the gap where the bushings used to be.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Exactly. It's better than stacking washers on both sides. You can buy any tube (aluminum, copper, steel), it isn't taking a huge amount of force, and get the right ID. Get a length of it, then chop it to whatever length you need.
And yea, rod ends are available from summit, but also mcmastercarr.com - they've got a good selection. QA1 is supposed to be the best of the best. Dust boots are a good idea, some racing outlets sell those. And finally, the tubing adapters (so you have threads), I've seen those on mcmastercarr.com for about $3/per.
Quick question for everyone else while we're on the topic - how would you make something adjustable length IF you did NOT use double rod ends? Like say you made something with poly on both ends, picture the stock panhard rod for example. Now what set of gizmos would you put **in the center** of that bar to make it adjustable length?
(I know if there is one rod end, you can unbolt it and let the rod end out further, but lets say you want to leave it in place to add some pre-load for example).
Don't mind me, i'm just piggy backing onto this thread. Thanks
Car: 86 z28
Sonix got the rest of my question with the extra spacer, I did not know that the spacer only went on the outside of the rod end. So I was confused on how you make it so the spacer would not slide on the inside of the rod end.
I was refering to these 122-XML10-12 at jegs that I have now been fowarded to.
Thanks fo the quick response
Car: 92 Z28
Engine: Boosted LSX
Car: 1982 Trans-Am
Exactly like that. What IS that in the middle? Basically two pieces of threaded rod, one right hand one left hand, with a nut over it? Welded together? That seems like a PITA, can you buy that middle "thingy" off the shelf? Does it have a name?
And then threaded tube ends welded into the tubing, and locknuts?
Car: 92 Z28
Engine: Boosted LSX
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
No is a threaded adjuster that is machined out of a soild hex stock. but yes there are 4130 threaded ends TIG welded into the ends of the tubes.
What the gent is talking about above, is the spacers inside and on the outside of the rod end.
There is a spacer in the middle that is just a bit smaller than the dia. of the hole in the rod end. Then there are two steel spacers on the outside of the rod end to keep it centered.
Car: 1982 Trans-Am
They are made like that so you can adjust em on the car. Not like the ones you have to undo one end to adjust em.
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Also check out http://www.speedwaymotors.com as they carry many different combos to make or modify suspension.
Car: 1982 Trans-Am
i'll be damned, thanks coolram62!
http://www.speedwaymotors.com/p/6844...Adjusters.html
"double adjusters". $22 is a bit much for that much steel, but I guess it's tricky to make so..
That's the type of site I don't really know exists. Thanks for answering my question guys.
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
http://www.lefthanderchassis.com/
nice for me because its 2 minutes from my house
but they have very good prices and have TONS of stuff in stock
but they have very good prices and have TONS of stuff in stock Thread
ambainb
Apr 25, 2016 09:21 PM
hectre13
Aug 26, 2015 08:17 AM
LT1Formula
Aug 20, 2015 09:36 PM
