Tire sizes on 15 inch rims
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
My 'bird has the stock rims on it. I like them so I have no interets in changing them right now. They are the 15x7s. The stock tire size was 215/65R15. The car had 235s on it when I bought but I have since put the 215s back on it. The 235s rubbed in the front. I'll probably stick with the 215s in the front because they are fine and I don't feel like replacing all of my brand new tires. However in the rear, now that I have started going to the dragstip, the 215s won't cut it in the rear. The sticky says that 255s will work on 15 inch rims but to stay below a 55 aspect ratio. I can find no such tire for a 15 inch rim. Will the 255/60R15s fit on the rear of our cars? I will most likely go with this size on my SS fairly soon, so I was wondering if they'd also work on a 3rd gen. Would a 225s fit well in the front? The options are a little more limited for that size, so that is another reason I think I'll stay with the 215s.
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Tire sizes on 15 inch rims
225s fit fine on mine in the front with no rubbing. For that matter my 235/60 15 Radial T/As didn't rub either. My 245/50 ZR16s don't rub either.
Maybe your suspension is a little low in the front?
Car: 88 firebird
Engine: 305 TBI
Car: '82 Camaro 11.7@121
Engine: 377
Transmission: 400
Axle/Gears: Dana 44 / 3.31:1
I always ran a 265-50-15...but that was on an after market 8" rim with 4" backspacing. They rubbed a little in front and not at all in back. Actually they fit the front a little better than a 235-60..but again this was not on a factoy rim.
It used to be you had a lot of selections in this size...but not anymore. I also see that the only one sold by tirerack.com also recommends a 7.5 inch rim minimum. So this may not be very useful information.
Engine: 400 SBC
Axle/Gears: 4.10
My 235s rubbed on hard turning. As far as I know nothing is wrong with my suspension. If there is it's nothing obvuious. I think the bushing in the rear are all shot, but the front seems ok.
Any verdict on the 255/60R15s?
They will look, and act, like the car is on balloons.
235/60-15 is just about ideal. Any bigger than that, is too wide for those wheels.
Engine: 400 SBC
Axle/Gears: 4.10
Really? That sucks. Oh well, I guess if I need to go bigger I'll need different rims.
toronto formula
Nov 10, 2015 06:17 AM
knight72
Aug 10, 2015 09:32 PM
