front strut/sway bar end link interference
Old Jul 15, 2007 | 09:18 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
Bilstein strut/Spohn sway bar end link interference???
I recently rebuilt my entire front end, and am having a problem with the struts and the sway bar end links hitting each other. they are Bilstein struts and a Spohn sway bar.
when the wheel is turned all the way to the left, the passenger side strut hits the sway bar end link, and when it's turned all the way to the right, it's the driver side strut hitting the sway bar end link. see the attached picture for a look at the driver side.
granted, the car is still on jack stands, so the suspension is fully extended which may throw off the alignment. i havent gotten the time yet to compress it further to see if it fixes it. in the mean time - any suggestions??
thanks,
-brian
Attached Thumbnails front strut/sway bar end link interference-dsc03057-small.jpg
Old Jul 15, 2007 | 12:41 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: front strut/sway bar end link interference
In looking at my '83 the stabilizer link is angled inboard with the suspension loaded.The Spohn bar's end appears to have a wider arc than the 36mm factory bar on my car.Is the Bilstein's lower section any larger in diameter than another strut?Once you put your wheels back on and put her back on the ground the angle will change and may alleviate the problem.Just my observation though.
Old Jul 15, 2007 | 03:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'd agree. Here's a pic of the 36mm on my IROC:
https://www.thirdgen.org/forums/atta...part-36mm1.jpg
JamesC
Old Jul 15, 2007 | 04:01 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
I don't think so, but unfortunately, my old struts aren't in the garage (they're in a storage unit). i'm going to grab them as well as the old sway bar to make some measurements comparing new to old.
hopefully you guys are right - the geometry will improve things once the car is on the ground. but if it doesnt, and that sway bar is causing the problems, i will ba making one unhappy phone call to Spohn. i don't want to jump the gun though - i have a lot of Steve's stuff on my car with zero problems.
i'll post an update when i can. thanks for the help so far..
-brian
Old Jan 31, 2008 | 05:50 PM
bullzz's Avatar
Car: 1984 Trans Am, 2003 Z06 Vette
Engine: zz383
Axle/Gears: 9" moser 3.70
Any update?
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
