Panhard bar hits my new aluminum rear end girdle.
Old Jul 15, 2007 | 10:54 AM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I just swapped out ALL of my rear suspension components except for the panhard bar... I also did a rearend swap while I was at it. I swapped from a nonposi 2.73 to a posi 4.11 both are 10 bolts except the 4.11 was built to hold horsepower as suggested from the tech articles. PROBLEM is that the new Aluminum cover has the 2 bolts that stick out a little to far in the middle and it hits the panhard bar. My temporary solution was to grind away on the panhard bar where it hits, i only ground out about an 1/8th of an inch and it seems fine now BUT I wanted to get an aftermarket panhard bar. I am pretty sure that this is going to cause a problem... any suggestions?
Thanks,
Dennis
Old Jul 15, 2007 | 12:03 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Panhard bar hits my new aluminum rear end girdle.
any tubular panhard bar will be fine and smaller in diameter than the stock counterpart
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
an aftermarket panhard bar will be tubular and therefore smaller
You shouldn't have any problems.
Old Jul 15, 2007 | 02:41 PM
Engine: 388 Carb
Axle/Gears: 4.10
Thanks guys, That is what i was worried about.
Do you suggest and adjustable one if the rearend is already centered with the stock length bar? I dont see any reason to get an adjustable one if its already centered but please inform me if there are other benefits...
Old Jul 15, 2007 | 03:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I run the Summit version of alum diff cover with Spohn tubular panhard and experience no problems. If you believe that you'll eventually lower the car, go with the adjustable; otherwise a non-adjustable should suit your purpose.
JamesC
Old Jul 15, 2007 | 04:17 PM
Engine: 388 Carb
Axle/Gears: 4.10
My car is auctually already lowered and it is still centered. I do plan on however installing a Spohn Tq arm but i dont see why that should have anything to do with centering the rear.
Old Jul 15, 2007 | 05:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the torque arm doesn't but the panhard does.
Old Jul 15, 2007 | 05:37 PM
Engine: 388 Carb
Axle/Gears: 4.10
That is what I am saying, Do I need an adjustable panhard bar if the car is already lowered and the rearend is already centered with the stock bar? I NEED to get a new panhard bar anyway, I am just deciding wether to get it adjustable or not because of the difference in money.
Old Jul 15, 2007 | 06:03 PM
JamesC's Avatar
If the rear end is centered, why are you debating the question?
JamesC
Old Jul 15, 2007 | 06:22 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
My car is lowered using Eibach Pro-Kit springs. Measuring the rims to check side-to-side and my rear is centred within 1/16". No need for an adjustable PHB. It will be the same in your case. Lowering the car SHOULD cause the rear end to shift to the drivers side enough to require an adjustable phb due to the decrease in the angle of the PHB. However, real world shows that until you've actually lowered the car and taken the measurements you won't know for certain if you need an adjustble PHB. Thank your luck that you don't need one and spend the savings somewhere else.
Lon
Old Jul 15, 2007 | 07:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
i dont know how much your car is lowered, but i put sportlines on mine and the rear moved quite a bit, so i had to use an adjustable panhard to line things back up, i guess if the rear is centered, there is no reason to buy an adjustable bar.
Old Jul 15, 2007 | 08:00 PM
Stephen's Avatar
Car: 87 GTA
Aftermarket Panhard bars are a waste of money. Just weld in a tubing piece to your stock one, or simply box it. $10 vs how much for an aftermarket one?
After boxing or tubing (or both) your stocker, the 1/8" you ground off (I'm guessing the lip?") will be of no concern.
Old Jul 15, 2007 | 10:00 PM
xpndbl3's Avatar
Car: 1984 Z28
I'd get an adjustable just in case in the future you might need it. It's not that big of a price difference, heck the lakewood one is under $100
Old Jul 15, 2007 | 10:04 PM
Stevo's Avatar
Car: Pair of 92 Z28s
I agree, if your spending the money for an aftermarket one go adjustable then youll never have to buy another one again.
Old Jul 16, 2007 | 02:23 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Get an adj... Just because in the future you will have the adjustability.
HOWEVER... here is some food for thought. I have a 12-bolt and the cover with the cap supports. The jamb nuts and little studs that stick out clear my spohn panhard bar no problem. NOW my cover hits the panhard bar brace alittle bit. I havent messed with it to see if I could shift the brace alittle toward the back of the car...but it has pretty much clearanced itself by now. Made a hell of a bang for a few miles then went away.
Just FYI... With the smaller rear it might not be an issue. But just check it out.
Justin
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
Jlanz55
Aug 17, 2015 07:15 AM
