lugnuts keep loosening
Old Aug 4, 2007 | 12:39 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Has anyone ever had this problem? I know the car isn't being tampered with either, It started after I put these N-24 wheels on the car and I'm using 84up style lugnuts. I had N-98 wheels on the car and never had this problem and I torque the lugnuts down between 85&90FT LBS
I've tried retorquing the lugnuts after a 10 mile drive and they still do it. Could it be the metal spacer plates I'm using? my lugnuts seat perfectly in the rims ..... or was there a thread difference between 82's and 84's? ... Or were the lugnuts changed from rim to rim? .... I generally seem to have to re-tighten them 1-2 times a week & it is getting aggravating to say the least
Old Aug 4, 2007 | 12:44 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: lugnuts keep loosening
junk lug nuts, replace them!
Old Aug 4, 2007 | 09:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Are you using 7/16 nuts on 12mm studs?
Old Aug 4, 2007 | 10:04 AM
Jproz1167's Avatar
whatever the stock studs are on a 82 and I'm using 1984 lugnuts. They seem to thread on fine
I am curious if maybe the taper ona N-24 wheel is different and causing this. or possibly just these spacers are the cause. these spacers are like 1/16th inch steel and I'm wondering if different heat expansions rates between these and the aluminum rims could be the cause too.
Denricci22
Sep 18, 2015 09:02 AM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
Fox118
Sep 12, 2015 09:29 PM
WickedBowtie
Sep 11, 2015 11:24 PM
TBRays98
Sep 6, 2015 05:05 PM
