15x8 Wheel Combo backspacing
Old Aug 12, 2007 | 06:47 PM
trnsam78's Avatar
Car: 1991 Firebird
Engine: 3.1 V-6
Axle/Gears: factory with 3.23......for now.
I have a 1991 V-6 Firebird that I want to replace the factory 15x7's with American Racing Torque Thrust D 15 x 8 wheel all the way around with 245/60/15's up front and 255/60/15's in back using B.F. Goodrich tires. Any recommendations on backspacing especially up front? I have 235/60/15's on the factory wheels and do get a little rubbing in full wheel lock turns so wanting to avoid that if I can stuff the 8" wide ones.
Yes, I know I can do 16" wheels, but it's a V-6, with only a little extra go power, still going to be more of a cruiser so being able to pull 5 g's in a corner is not a concern.
Old Aug 12, 2007 | 11:43 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 15x8 Wheel Combo backspacing
Best bs would be 4.5" for 8" rim and 3.5" for 7".
The 245 seems a little tall. It is a 26.6" tire and the 255 is 26.8". Stock tire height is 26". On the back go with a 275 50 on an 8" rim and front 235 60 on a 7". This would keep the height at 26". The taller the tire the more it will throw off your speedo.
Good luck
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
rb85TA
26
Sep 14, 2015 10:29 PM
scottmoyer
Sep 7, 2015 07:06 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
z28guy134
Sep 1, 2015 11:50 PM
