How well will 17x9.5 fit?
Old Aug 22, 2007 | 11:50 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
I have been looking at some gunmetal C5 wheels(cheap) and want to wrap them in 275 meat all the way around, i will probably use a 4th gen rearend and 2 inch spacers up front on my 86 TA, i want to know how it will fit up front, i know the back should be fine, any idea on how well it will clear?
Old Aug 22, 2007 | 06:45 PM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Re: How well will 17x9.5 fit?
Nobody know??? I would love to have 9.5 wide with 275 tire in the front.
Old Aug 22, 2007 | 07:42 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Here is my car with 17x9.5 ZR1s. They are on a 2" spacer in the front and a 4th gen rear on the back...
Old Aug 23, 2007 | 12:29 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Go to my Garage. I got a 86 with 92 Ronal R15/Firehawks. 17x9.5, fronts have a built on slim spacer, tires are Falken Ziex ZE-512 275-45-17....no issues, lookk and handle great.
Old Aug 23, 2007 | 11:13 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Awsome, thanks guys, 91_5.7_TPI your car looks sick, super clean man nice job.
Old Aug 23, 2007 | 01:50 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
nice!
Old Aug 23, 2007 | 07:01 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
hey 91_5.7_TPI is yours lowered at all? do they rub at all now? I was thinking about c5 z06's on my vert but I have 1.8" (I think may be 1.6") drop spindles going on. It will have new struts and shocks and springs though.
Old Aug 23, 2007 | 07:31 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
thanks guys. I need to take some better pictures. Mine is lowered on a Pro-Kit (see signature). It rubs on the left front when I turn the wheel locked left. It's not bad, but it's enough for me to not turn the wheel to lock unless I have to.
Old Aug 23, 2007 | 07:44 PM
jstoltz's Avatar
pro kit is comparable to the drop I will have so I guess I will be in store for the same. is there anyway to clearence it? If you can please get some pics of it turned all the way left and right.
also what offset are the zr1's? skulte has the gs zr1's and high and low offset zr1's listed I am not to familiar with them.
Old Aug 23, 2007 | 07:48 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Yea, I'll get some tommorow after work if I get off in time to do that and change the oil in the van. It is just rubbing on the plastic piece in the wheel well.
Old Aug 23, 2007 | 07:54 PM
jstoltz's Avatar
thanks that sounds like it should be an easy fix. I wanted to use the c6 five spokes but if these are 17x9.5" and they rub the c6's may be more of a pita than they are worth.
Old Aug 24, 2007 | 06:43 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I don't think that a larger wheel will affect the fitment. What I'm trying to say is that the overall outside diameter of the wheel/tire should be very close and the width of the tire should be the exact same. I don't know for sure though.
Here are the pictures you asked for.
hehehe
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
BOOT77
Sep 5, 2015 03:55 PM
