Kind of confused..
Old Sep 2, 2007 | 11:50 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Kind of confused..
I am unsure if a smaller tire height is better or worse. I am too tired to figure it out the old physics way. lol But if someone could help me. I have 15 inch rims. with 235 width and 60 height. I am thinking of goin to like a 235/50 up front and 245/50 in back. I just wanted to make sure that going a lower height is better
Old Sep 2, 2007 | 02:00 PM
novatuc's Avatar
Car: 1984 Trans Am
Re: Kind of confused..
Smaller sidewall will always ride rougher but will handle better.
Old Sep 2, 2007 | 02:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
and as far as speed is concerned, a smaller tire with accelerate faster, and loose top end, a larger tire will accelerate a bit slower, but have improved top end charge. with a difference of about a half inch or so, i see no problems
Old Sep 2, 2007 | 03:35 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ok last question is how much a change is from a 60 size tire to a 50.?
Old Sep 2, 2007 | 07:07 PM
novatuc's Avatar
Car: 1984 Trans Am
The 50 and 60 are percentages (basically). A 235/60-15 tire is basically 235mm wide when mounted on a proper size rim, inflated to the proper pressure. The 60 means the sidewall height is 60% of 235mm when mounted on blah blah blah. The sizes are just a guideline as no two different brands of tires will be exactly the same even if they are labelled as the same size.
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
hartsmike
Oct 2, 2015 07:11 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
