need help with 60 foot times!
Old Oct 1, 2007 | 05:52 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Before somebody says it i know well each car is different as is each engine and setup. My suspension mods are umi panharad bar (non adjustable), and Lakewood LCA. I tried putting the Spohn LCARBS on but cant get it down yet. It seems that the Lakewood LCA's are too long for that. I really wanted to have them bc i have heard nothing but good things ab LCARBS.
Anyways, my 60 foot times are consistently 1.97, weather i am powerbraking to 1700 (max i can powerbrake to with the crappy brakes i have out back, and yes i am upgrading those), or flashing the converter from an idle. My 383 is only running a 12.89 at 107 mph and I know there is more than a 1.97 in my setup, especially with MT ET streets!
So i am asking you guys again for HELP!!
Old Oct 1, 2007 | 06:53 PM
DIGGLER's Avatar
Re: need help with 60 foot times!
put your gear and converter in there before messing with the suspension. bone stock suspension should work fine for you at this point.
Old Oct 1, 2007 | 07:22 PM
Car: 92 Camaro
Axle/Gears: S60 373
https://www.thirdgen.org/forums/orga...e-convert.html
think i found the answer here.....pretty much what DIGGLER said...
Old Oct 2, 2007 | 02:00 PM
Shagwell's Avatar
Car: projects.......
gears and converter would be the first thing. Then figure out what you were doing wrong w/ the lcarb's. Lakewood arms are stock length, as are all other brands.
fasteddi
Sep 2, 2015 10:29 AM
B_Dubya
Aug 26, 2015 05:09 PM
EFR2000
Aug 18, 2015 08:54 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
