specs for stock 15" Z28 rims?
Old Oct 16, 2007 | 07:25 PM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
does anyone know the backspacing and offset for stock 15" Z28 rims?
also, i've researched a certain wheel size for my stock 86 and i think it will fit based on what I see on these boards: 15x8, 5 on 4.75, 3.25" backspacing with -30mm offset.
does anyone have a strong opinion about those fitting or not? seems like they should. they're eagle alloys 058 series and i can get a decent deal on them used.
thanks for your help.
Old Oct 16, 2007 | 08:05 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: specs for stock 15" Z28 rims?
The 15" 5 spoke wheels are 5 on 4.75 bolt pattern,7" wide,0mm offset with 3.25" backspacing(I'm not 100% certain on this).Check this link from the tech section to make sure your wheels will work.
http://www.skulte.com/adapterfaq.html
Old Oct 17, 2007 | 05:22 AM
BigBiscuit's Avatar
Car: 86 Iroc-Z28
thanks for the reply and the link.
Old Oct 17, 2007 | 06:55 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Original 15x7 wheel->backspacing=110mm,offset is +8mm
Orr89RocZ
Apr 25, 2016 08:28 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
antares57
Aug 6, 2015 07:47 AM
