anyone use PA racing bumpsteer kit?
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
http://www.lonniesperformance.com/paracing.htm
are there any modifications to the spindle to install these or do they have the same taper as the tierod? what kind of tierods do i use?
Car: 1983 trans am
Re: anyone use PA racing bumpsteer kit?
guess not? well i maybe the guniea pig then.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
afaik, they will need to be drilled to accomadate the grade 8 bolts included in the kit.
ive never installed one on a 3rd gen, but most kits will require drilling the hole out.
did you install a rack n pinion kit from them?
Car: 1983 trans am
i was worried these would only work with a rack. no i do not have a rack in it. is there any bumpsteer kits for the oldstyle crossover steering?
Baer bumpster kit. Note: the picture on the SDparts link is not correct, but thast is the correct part # for a 82-92 f-body.
http://www.sdparts.com/product/BAE33...pSteerKit.aspx
http://www.cardomain.com/member_page...52_71_full.jpg
Car: 1983 trans am
did u have to drill out your spindles?
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Yes you have to drill them out to 1/2in. It's really not that big of a deal, go from the bottom and work slowly.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Drone358
Dec 10, 2015 08:16 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
