steering wheel loose common problem??
Old Oct 29, 2007 | 09:09 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
ive never had this happen to me b4 but this car has a loose steering wheel like the tilt is loose or something? i see theres a post on how to repair it but what are the chances i may need a new steering coulmn? and is this common among the f-bodys and how does it happen ? people using the wheel as anchorage to get out of the car??
Old Oct 29, 2007 | 09:27 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: steering wheel loose common problem??
If you mean when you pull on the wheel it tilts downwards like you had pulled the tilt lever but you didn't, my wheel does that too, not sure how to fix it.
Old Oct 29, 2007 | 09:38 PM
cajunnola's Avatar
Car: 1992 Camaro RS
Engine: 305 (for now)
Transmission: 5-speed
Axle/Gears: stock
I have had 3 gen 3s thay all did it I am sure it can be fixed I am curious how I never worried about it with me other cars but I would like this one done right so I was going to look into fixing it.
Old Oct 29, 2007 | 09:47 PM
Bandit5's Avatar
I took my entire steering column off, took it apart, and then put everything back together nice and tight. The column is now very tight. I don't pretend to know exactly what I am doing all the time, but sometimes I get lucky. So I suggest taking it apart and seeing if you can find a cause for the looseness and tighten it.
Old Oct 29, 2007 | 09:58 PM
Guest
Guest
Posts: n/a
The bolts that hold the tilt mechanism together come loose over time. Its a pain to get at them, have to pull the pivot pins and pretty much everything else. Do a search, you'll find a lot of posts about it. Use loctite when you reassemble those bolts.
Old Oct 30, 2007 | 01:44 AM
Car: 1985 TransAm
Engine: 5.0L TPI
am i in danger of the steering wheel falling off or needing to replace the column?
Old Oct 30, 2007 | 01:53 AM
BobItzaboy's Avatar
No, its safe. It will not come off there, However, the mechanisms inside can start to wear prematurely and eventually you loose things like the ignition cylinder will start to malfunction and other interanl parts like the turn signal etc can break for the tilt column slopping about. You really should have it fixed to avoid future breaking of internal parts that will eventually lead to the column itself cracking and unfixable. A new steering column will set you back alot more than the aprox $60 to have a shop with the proper column jig get it apart and tighten things back up
There are four bolts in there that loosen, two of them easy to get to, one is somewaht troublsome, and the last is well, lets just say it is not fun.Late model GM tilt columns are notorious for this problem in all GM cars after about 10-15 years of good use.
Old Oct 30, 2007 | 09:24 PM
Bandit5's Avatar
My right turn signal switch broke... while replacing it is when I did all that.
Old Nov 4, 2007 | 11:28 AM
Azrael91966669's Avatar
Car: 1991 camaro RS
Engine: CharlesOdoryOB
Transmission: 82513892892
Axle/Gears: pbr disc 3.27 nine bolt
it is a common problem as many people use the steering wheel to get in and out of the car
i took mine completely apart just to find that everything was tight but im also missing one of the tilt settings but mine dosnt go all overthe place like some do
Old Nov 4, 2007 | 08:35 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i also heard something about bearings going bad?
Old Nov 4, 2007 | 09:16 PM
jstoltz's Avatar
Car: 1987 Iroc-z Convertible
one thing that sucks pretty bad is if your column gets real loose like my last Camaro the plug for the ignition stuff can come loose when you are turning and kill your ignition. mine the screws were loose and they had to change a bearing race that went bad. charged me $280 or a lttle more to fix it but it was because I didn't have time to fix it. could have done it myself for around $45 and after charging me out the a** they call me to pick it up and they put the fu**ing steering wheel upside down so I had to stop at AZ and buy a puller and fix it myself or wait another hour for them to get to it.
Old Nov 8, 2007 | 01:25 PM
Chrisry1995's Avatar
Car: 89 Trans-Am
Engine: 5.7 TPI
Yes, very common problem with tilt wheel. Most of time just loose bolts and the other are right,USE LOCKTITE !!!! Wheel is loose in every direction. Very fixable problem. You don't need a new colum, just take you time and be very patient. Sometimes it helps to take pictures of the switch and inners to help put everything back. If you do it or have someone else do it, USE LOCKTITE. I didn't the first time and it go loose again after a year or so.
Old Nov 8, 2007 | 08:40 PM
Car: 1985 TransAm
Engine: 5.0L TPI
my steering wheel only moves down and to the left sorta like a J do u think its just the bolts ? or something else?
Old Nov 8, 2007 | 09:28 PM
jstoltz's Avatar
just means you have one bolt still tight. same problem though.
Old Nov 8, 2007 | 09:39 PM
Car: 1991 camaro RS
the problem some have is when something is broken
like mine it dose not move freely it moves only under force
i checked my bolts all are very tight
but good example is i have to pull hard down on the wheel to turn on the hi beams
the loose bolt problem the wheel moves around freely sometimes side to side
or up and down depending on what bolt it is
Old Dec 22, 2007 | 04:10 PM
Blakcamaro's Avatar
Car: 86 iroc
Engine: 496ci
Transmission: stock t5
Axle/Gears: stock/323 posi
mine also pulls down and to the left, if i have my ignition turned to accessory and i pull down on it then it shuts the accessories off. it hasn't turned the car off while its running though.
Old Dec 23, 2007 | 09:54 AM
Car: 1991 camaro RS
its the pin that connects the 2 parts of the tilt setup
Ghettobird52
Jul 5, 2024 11:18 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
