Can I run long tubes...
Old Oct 31, 2007 | 01:43 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Do I have the clearance to run long tubes on an 88 IROC vert dropped with jamex springs approximately 1.5" I have a 383 with the fastburn heads waiting to go in and would like to go with Hooker 2210's? or are shortys my only option? thanks
Old Oct 31, 2007 | 02:26 PM
Shagwell's Avatar
Car: projects.......
Re: Can I run long tubes...
The headmans tuck up closer than the hookers. I've never personally run the hookers, so I can't speak for them, but I had no issues with my headmans and a 2" drop.
You would get more response on the exhaust forum.....
Old Oct 31, 2007 | 03:11 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Hedmans>>shorties 68479's or long tubes?
Old Oct 31, 2007 | 04:42 PM
Shagwell's Avatar
hedman LT's
Old Nov 1, 2007 | 12:03 PM
radialtireking's Avatar
Car: 85 Camaro
Engine: 437" small block
Transmission: glide
Axle/Gears: 3.70
The hooker long tubes tuck up nicely under the car. They are about even with the bottom of a stock k member or just slightly below a tubualr one. My car is pretty low and I never had issues with the headers. My clearance issue was with the exhaust where it dropped under the trans crossmember. My car also has 3.5" exhuast on it which dosen't help.
Old Nov 2, 2007 | 05:33 PM
Shagwell's Avatar
humm... Every other person w/ the Hooker LT's has complained of them hanging too low. From what I've read they hang a good inch below the hedmans, but that's why they clear the slave cyl on manual cars while the hedmans won't. - My car was manual, but I ran a (non-3rdgen)sfi bellhousing w/ the trans standing up straight and custom clutch linkage.
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
