Paint for rear axle.
Old Nov 1, 2007 | 12:33 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Just got done dropping the entire drive train on my second camaro and i want too clean up and repaint the rear axle. The last rear axle i did i just undercoated b/c it wasnt meant too be a show car this one i want it too look good but it needs too be durable bc i want too be able too powerwash it etc. Anyone know of some good black paint that would do the job? ive heard of this por-15 <not sure if thats right lol. Does it leave a smooth finish?
Old Nov 1, 2007 | 05:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Paint for rear axle.
I used POR-15. Still looks good after several years.
https://www.thirdgen.org/forums/atta...-89-guides.jpg
JamesC
Old Nov 1, 2007 | 12:19 PM
BobItzaboy's Avatar
I use gloss black Epoxy paint from home depot on all my undercarrige and engine bays. Anywhere grease and dirt is a problem. Its strong paint and inexpensive. Very durable and protects things from rusting.
Old Nov 2, 2007 | 12:26 PM
mlaudon's Avatar
Car: 89 Camaro Rs
Engine: 355 build up
Transmission: TH350
Im getting ready to do mine and i think im going to put tractor paint on or just regular black engine paint. Ive use the engine paint on some of my suspention and driveshaft and i like how it turned out.
Old Nov 2, 2007 | 01:26 PM
oil pan 4's Avatar
Car: 89 Firebird
I used 40grit on the bad stuff, a wire brush on every thing, an air blower to remove dust, Rust Neutralizer as primer and a few big old cans of black rust-oleum. I put 2 or 3 coats on every thing and 3 or 4 coats on the "bad" areas.
It's not going to look great unless you take the time to sand off all the rust.
Engine paint would be good to, I didn't think of that. It would be thicker.
It does look good. When you put it on a lift people will know you are hard core about your car. A Painted sway bar adds to the effect.
Hit the steel break lines with paint while your at it, some states won't let you pass inspection if they see rusty break lines.
The key with any paint will be to give it a good surface to stick to.
Old Nov 2, 2007 | 03:39 PM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
JamesC
I did the same I used por 15. Works great.
Old Nov 3, 2007 | 08:14 AM
Frank89IROC's Avatar
Agree I used POR-15 on my 89 IROC & 94 TA, rust never came back. They have black gloss or if you prefer black semi-gloss.
Old Nov 3, 2007 | 12:36 PM
Lol dont worry ill be sandblasting the thing before i paint it so it will be bare metal i just want the paint too be durable and look good thanks for the input ill porobably go with the por-15 or engine paint probably do a coat of rust oleum primer first thanks for the inputs.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
neekolzun
Aug 24, 2015 04:59 PM
