CLUNK
Old Nov 6, 2007 | 03:03 PM
turbo2825psi's Avatar
Car: 1992 RS Camaro
Engine: 5.0 tbi
Axle/Gears: stock 10 bolt 3.08's
CLUNK
just wondering ive got a 1988 camaro no wonder bar or sway bar the day before i went to get them i started to hear a loud clunk coming from what seems to be the gear box. i do drve it hard especially cornering. could i have craked my k member. also all bushings look good also no play in the ball joints, and new struts and loiring springs.
Old Nov 6, 2007 | 03:08 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: CLUNK
Double-check the trans mount.
JamesC
Old Nov 6, 2007 | 03:13 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
Re: CLUNK
the trans mount is solid same with th torque arm. rear bushings are good. it also does it when i go over a bump with the left tire also
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: CLUNK
i second that, it seems to be a popular problem.
Old Nov 6, 2007 | 03:16 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
Re: CLUNK
one more thing when im siting still and crank it all the way to the left it clunks
Old Nov 6, 2007 | 05:39 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: CLUNK
check your panhard bar / trace brace bar . it goes from r/h side of axle to l/h side of body . on my 89rs all 3 bolts that secure brace to body had fallen out . weird handeling and CLUNK . replaced bolts , all was good . if this is your problem , clean female threads and use locktite on new bolts .
Old Nov 6, 2007 | 08:57 PM
ryan91rs's Avatar
Transmission: 4L60
Re: CLUNK
i get a similar sound from the front end when i almost lockout my steering.
Old Nov 6, 2007 | 10:57 PM
Car: 1992 RS Camaro
Engine: 5.0 tbi
Re: CLUNK
well when i lock my gear box repetidly i get the clunk and it deffinetly is coming from the front by the gear box j/w if my k member is craked is it behind the gear box or visual its really tiking me off
Old Nov 6, 2007 | 11:02 PM
ryan91rs's Avatar
Transmission: 4L60
Re: CLUNK
i have the same problem so i don't think you cracked your k member. I think it's a front end wear issue for me. lots of miles and loose front end.
Old Nov 8, 2007 | 08:05 PM
YigyYo's Avatar
Re: CLUNK
I just came across a clunk on my 88, but come to find out it was a stabilizer bar link that had snapped in two. not sure if you checked already.
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
