Benefits of runnning aftermarket strut mounts?
Old 11-16-2007, 11:49 AM
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
I'm looking into replacing my strut mounts since I'l be running Tokico 5-way adj. shocks w. Eibach Sportlines.
I'm looking at the Spohn strut mounts, besides being able to adjust camber/toe angle, do the strut mounts help with ride quality?
Old 11-16-2007, 02:01 PM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
Re: Benefits of runnning aftermarket strut mounts?
Yes, if you replace the old shocks and don't replace the mounts(if they are old and worn) the car will still had bad ride quality. It's recommended that you replace them every time you replace your struts, but most people don't. I also have been looking at tokico shocks. Tell us your opinions when you get them done since there really isn't a yea or neigh concensus on those yet.
Cheers!!!
Ohh by the way that car in your sig is gorgeous. I have not seen a better looking third gen in a while.
Old 11-16-2007, 02:34 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The OE's have some rubber to soften the ride. Spohn's don't, so I'd think the ride quality would be affected adversely. Others with experience with Spohn's version may offer better help.
JamesC
Old 11-19-2007, 10:55 AM
On Probation
TPI TERR's Avatar
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
thanks for the info and compliment, it does make sense that a stock replacement with rubber would absorb more vibration leading to a smoother ride.
My concern was that the Spohn units are 1" taller than stock to provide extra strut travel for lowered cars. So what would be more beneficial, the extra inch from the Spohn units or the fact that the stock units would absorb more vibration?
Old 11-19-2007, 12:02 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Hotpart also makes one that's considerably cheaper than Spohns, and a lifetime warranty. Just another option.
Old 11-19-2007, 09:55 PM
BobItzaboy's Avatar
.... do the strut mounts help with ride quality?
Thats a loaded question and I'll explain why.
Ride quality is in the eyes of the beholder. You want soft Cadillac forgiving ride then keep your older worn out factory strut mounts because that old worn rubber will absorb some of the initial bump impact undampered and give a bit more feely until the rubber flexes to a point where the strut begins to damper.
Handling wise and performance? It takes out all the undampered slop that causes the chassis to bounce freely in a tad bit of up and down no mans land of rubber bushing defection. Your tires can travel up and down as much as 1 full inch undampered if those factory mounts are than worn. Replacing them with solid mounts and then bouncing on the fender of the same car will make it much more firm.
Now as for taking out thhe basket ball dribble after a bump? Yes that does help eliminate this undampered travel and smooth the car back to a settled chassis quicker. Its a give and take opinion.
redmaroz
04-25-2017 07:14 AM
83 Crossfire TA
01-03-2016 01:26 PM
Hotrodboba400
09-02-2015 07:28 PM
IROCZDAVE (88-L98)
09-02-2015 08:49 AM
IROCZDAVE (88-L98)
09-02-2015 08:43 AM
Quick Reply: Benefits of runnning aftermarket strut mounts?
