weld rims,best fit?
Car: 87 Silver Formula
weld rims,best fit?
I can get a nice set of mismatched offset weld draglites.The rims are 15x9 with one set having a 3.5 backspace and the other a 4.5
which ones would be the best fit for front and rears?
3.5 in front or 4.5?
Re: weld rims,best fit?
with a 15x9 you would most definitely need the 5.5bs
for fronts i just run the 15x4 with the only backspacing choice you get. As these are a drag racing rim, I don't see the point in putting a 15x7 or similar front onto the car since they will bend if you take corners too fast. Doesn't sound like your good deal will bolt up to your car.
and i was told on this thread that 3.5 backspacing would work
https://www.thirdgen.org/forums/susp...need-info.html
15x4?
both set i am looking at are 15x9
are you saying run skinnies on the front?
reason i am asking is the set(all 4 rims ) are 15x9. I can get smaller rims but i do not want a street driven car with skinnies...looks kinda stupid.
what i am sking is about the backspacing.One thread says 3.5 on 8 inch rims will be ok.
now this thread has 3.5 and 4.5 BS rims and now neither will fit?
Street Lethal
04-30-2019 12:14 PM
ambainb
04-25-2016 09:21 PM
Djmathis123
09-29-2015 01:36 AM
