drag launch springs
Old Jan 3, 2008 | 12:28 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
drag launch springs
who makes a kit for a thirdgen?
Old Jan 3, 2008 | 07:51 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: drag launch springs
What do you mean by kit? You can buy Moroso trick springs to replace your stock ones.
Old Jan 4, 2008 | 07:19 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Spohn offers a coil-over conversion kit that looks quite tasty. Both front and rear. Looking at just over a grand for both ends of car. Is definitly on my short list of upgrades.
Old Jan 4, 2008 | 11:45 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I found that Ed Quay makes springs for 3rd gen www.edquay.com I am putting in a big block, they make a set for BBC and SBC designed for weight tranfer, but says will keep the car at stock height. Since I plan on using the Racecraft dropped spindles, I do not want the spring to lower the car any more. Hope that helps
Old Jan 8, 2008 | 12:50 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
im looking to get some more weight transfer fairly cheap. ive heard that eibach makes i kit but i havent seen it. the moroso springs suposibly suck to put in because you have to keep cutting them to fit, this car is also street driven on occasions.
Old Jan 8, 2008 | 02:25 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i havent heard that one before. can anybody verify that because was looking at those springs.
Old Jan 9, 2008 | 10:16 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
people on other forums have told me that you need to cut them to get the desired right height. if not it will look like its lifted.
Old Jan 9, 2008 | 10:46 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
if you get he moroso spring you will need to cut them, you have to install them first and after a day or two you will need to take them out and cut them to ride height
Old Jan 9, 2008 | 11:07 AM
impaled's Avatar
thanks for the info.
Old Jan 10, 2008 | 09:44 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
how many of you have the moroso springs? they claim they are not streetable, but neither is my spool, front tires and rims, my 90/10s and no sway bar. how bad are trick springs? can you use them on the street?
Old Jan 10, 2008 | 10:21 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
you can drive them on the street, i did. i got coil overs from pa racing they are the sh*t! hell with them bid springs and getting you're fingers smashed
Old Jan 12, 2008 | 01:12 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i have 2 different sets of eibach drag launch springs for sale..... LMK.
Old Jan 12, 2008 | 01:30 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
interest pm me with info.
Old Jan 13, 2008 | 08:49 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
any alternatives cheap?
Old Jan 13, 2008 | 09:17 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i found the eibach kit for $285 the part number is 9306-140 am i correct? ive been told that it will make the car sit really high is that true? and if it is if i do the heater hose mod will it put it back close to stock?
Old Jan 13, 2008 | 10:03 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i run the moroso sbc trick springs(220lb/in), 90/10's and no front sway bar on the street.. its on my daily driver/racer.. its like riding a car with blown suspension.. really soft and gives more body roll than normal.. im about 3100lbs with the stock steel hood and she sits with about 3-3.5inches of fender gap.. on those hard shifts, it will fully extend..
Old Jan 14, 2008 | 07:19 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
see thats what i want! that suspension works. will it dead hook at the track? i think you run the same tires as me. what rear springs do you run?
Old Jan 14, 2008 | 08:12 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
i was talkingto a chassis builder in ocala, andhe said the rear factory spring work really well.
Old Jan 14, 2008 | 12:46 PM
5678TA's Avatar
Car: 1984 Trans Am
well for me, it doesnt hook nearly how it should.. mainly because my car is gutted and i'm running a manual with 4.30 gears.. i spin a bit off the line and when i drop it in second, on a good run, i can lift the front tires.. i still manage 1.6x-1.70 short times with 28.5x11.5-15 hoosier qtp's.. the tire in my sig was the old drag radials 275/50-15.. that hooked like crap, best of 1.81 with a 3.89 gear.. manuals and DR's dont get along too well.. i recently added 120lbs of weight in the trunk but havent been able to get back to the track to test it.. but i will say that it does leave marks on the road alot more frequently.. for rear springs i use the stockers and i have some old replacement shocks..
EDIT:also forgot to add that i only had tire pressure at 18lbs.. any lower would want to shimmy at the top end.. didnt really feel like meeting the guard rail that day..
all in all i think it would work great with your auto combo.. autos seem to hook up easier than manuals..
heres a recent video without the weight.. i spin hard off the line and hook hard in second..
Old Jan 14, 2008 | 12:57 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
so i should leave my stock rear springs and get a good set of fronts? moroso or the eibachs? or is there something else?
Old Jan 14, 2008 | 06:09 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
it will only make the rear sit high.
i had no issues with the front.
they appear high at 1st, but once they settle in its no higher than stock. (FRONT ONLY)
Old Jan 15, 2008 | 12:14 PM
Shagwell's Avatar
Car: projects.......
$285 for a set of drag launch springs? Find a decent parts house with a Moog coil spring catalogue. Look up your factory spring pn, reference it's specs in the back of the book and find something thats got a taller free height and a lesser rate with the same end orientations, viola for under $100.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
