Need A Strut Tower Brace?
Car: 1987 Firebird
Engine: Present=350/4brl, Future=455 H.O.
Transmission: Present=700R4, Future=Richmond 6Spd
Axle/Gears: Now Stock, Later 3.73
Do you guys know any i could use with a 350 Carb'd/
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Need A Strut Tower Brace?
Any TBI one will work.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Just an FYI: There are no STB's that will fit a carbed car with the the AC compressor on the driver's side.
JamesC
JamesC
Car: 1984 z28 camaro / 2019 accord sport
Any tbi one should fit. You could always make your own. There not too hard to make if you can weld.
Car: 1987 Firebird
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
wouldnt it matter if hes running a raised intake? idk the specs of the TBI braces but im sure if u run a taller intake/cleaner etc that it mite not work.
thats why the TPI braces dont work wit the HSR >:0
just make your own, the edelbrocks are $$$ for basically nothing lol
Car: 1987 Firebird
Car: 1991 Camaro
Engine: Morris 434 Single Turbo
Transmission: TH350
Axle/Gears: 9" Ford w/4.11's
"The Edelbrock WILL work if you modify the AC bracket."
?? I got a 406 and a 355 in 2 different camaro's and I just used the Edelbrock TBI brace, it worked just fine with A/C
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
AC compresors came from the factory with it mounted on either the right or left sides. If your mounted on the pass side the Edlbr. will work fine. The problem arises when you have the AC mounted on the drivers side.
Car: 1987 Firebird
Guys i have no A/C at all its completely put box condenser and compressor.
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
84 T/A, 305 and carbed here.
So, since my AC is on the drivers side I'm basicallys screwed and won't find a STB that will fit?
What needs to be done to modify the AC bracket?
JamesC
Car: 1984 Trans Am
LT1Formula
Oct 8, 2015 08:34 PM
tcflint
Sep 27, 2015 05:58 PM
You might check out the Edelbrock three-point.
