Rear Coil Spacer Lift Kit?
Old Jan 10, 2008 | 07:16 PM
blue82_z28's Avatar
Car: 1982 Camaro Z28 w/ RS groundfx
Transmission: Tranzparts 700r4
Axle/Gears: 3.23's
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
Just wondering what the benefit would be?
Old Jan 10, 2008 | 07:28 PM
jhyneman's Avatar
Car: 91 transam GTA
Engine: 5.7 tpi
Re: Rear Coil Spacer Lift Kit?
I can think of a couple of different reasons to use them. I used mine for added tire clearance because I put bigger tires on the back.
Old Jan 10, 2008 | 07:29 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
What size tires are you running?
Old Jan 10, 2008 | 08:01 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Depending on how much lift you are looking for, you could use 4th gen rear spring rubber isolators. They will raise the rear end up about 1". I used them with Eibach springs all around to get a nice aggressive stance.
Old Jan 10, 2008 | 10:31 PM
blue82_z28's Avatar
Axle/Gears: 3.23's
Well, with the tallest ones, how big of a tire could i fit in the rear(Standard street tire, not drag radial)??
Old Jan 10, 2008 | 11:31 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
you'd be limited to 29" or so with some fenderwell mods.
Old Jan 11, 2008 | 06:52 AM
jhyneman's Avatar
Car: 91 transam GTA
Engine: 5.7 tpi
I put 29's on mine fit nice.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
kah992
Aug 19, 2015 02:55 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
