best manual valvebody??
Old Jan 11, 2008 | 08:57 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
what is the best manual valvebody for a 700r4? i have a tci and it has fried 4 transmissions. looking to get rid of it and go with something else. anyone using the ati one?
Old Jan 11, 2008 | 09:35 AM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: best manual valvebody??
oops wrong forum how do i move this to the transmission section? lol
Old Jan 12, 2008 | 01:10 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
its not the valve body thats frying transmissions.
its the trans builder.
Old Jan 12, 2008 | 01:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Starting off in D with a manual valve body will also fry a transmission unless it still has an automatic feature while in D. The valve body itself won't fry the transmission.
Old Jan 12, 2008 | 01:27 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
i shift it manually through all gears, i dont leave it in drive. the valvebody is what is causing it to flare into third gear. i changed nothing but the valvebody and this occured.
Old Jan 12, 2008 | 01:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
you can try to mess with the accumulator.
i dont know the exact parts you have, but there are several shim and spring mods to try and stop the issue.
Old Jan 12, 2008 | 02:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
What part number valve body did you use?
Old Jan 12, 2008 | 06:13 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
ive got the one with engine braking,
Old Jan 12, 2008 | 06:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
376015 Full manual, reverse pattern, engine braking.
http://www.tciauto.com/Products/Inst...76015_inst.htm
I have to assume all the modification required were done properly? No parts were left out or not done? You didn't lose the check ball under the aux valve body?
Providing everything was installed and modified properly I only have a couple of suggestions.
A poor or misadjusted TV cable.
Worn or improper clearance 3-4 clutch pack.
Worn, improperly modified servo
There's a crack somewhere causing a pressure leak.
Install a pressure gauge and get readings in all shifter positions.
Pulled from another forum
The main things that I have seen that affect the 2-3 shift are;
2-4 servo travel
3-4 clutch pack clearance
Sealing ring damage on the input shaft. Usually, caused by bad stator bushing(s).
Servo piston pin bore wear is usually not a problem with the 700.
Check all accumulator piston pin bores for wear. There should be a slip fit clearance only. Any rocking of the accumulator pistons on their pins is a crossleak and a big no no.
Last but not least. The quality of the 2-4 band and the 3-4 clutch pack friction material. Any glazing of these friction elements will greatly affect the syncronized timing of the 2-3 shift. The friction elements can be slightly burnt and not leave any debris in the pan.
Any problems that can affect line pressure. Worn TV boost valves, plugged filter, worn out pump.
If you think it's the valve body, change the tranny back to original and see if the flare goes away.
Old Jan 12, 2008 | 06:32 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
its working good at the track just flares on the street.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
