Is this a common reinforcement method on these cars?
Old Jan 25, 2008 | 06:27 PM
TurboM3's Avatar
I just bought the car recently and the previous owner didn't know anything about it. I'm wondering if the reinforcements pictured below are common/useful on these cars or is this un-needed weight?
Old Jan 25, 2008 | 06:34 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Is this a common reinforcement method on these cars?
Those look like subframe connectors, they do real good on the rigidness of the car if properly installed.
Old Jan 25, 2008 | 06:45 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
if done right , they are great . take some more pics. when on a lift . you will get many more reply's , and opinions .
Old Jan 25, 2008 | 06:54 PM
TurboM3's Avatar
Well I can tell you right now the welds are kinda shoddy. I'll get some better pictures within a few days here but I'll probably end up cutting them out and redoing from scratch.
Old Jan 25, 2008 | 08:23 PM
camarojustin's Avatar
Car: 88 camaro
Engine: 355
Axle/Gears: 3.73 posi
Looks like do it yourself sub frame connectors. Do they actually connect the subframes? It pretty much looks crappy anyway, it should really be tacked along the rest of the underside of the body.
They are basically a nessecity for 3rd gens if you want any performance out of them. It tightens up the whole car making it handle better by keeping the car from twisting as it does not have a frame.
Old Jan 25, 2008 | 08:24 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Are they just straight peices of bar or do they have any Y's to them? where are they welded too? look up subframe connectors for our cars at spohn, umi, etc, see if any resemble what you have. They do look kind of basic however. Would'nt be suprised if they were home made.
Old Jan 26, 2008 | 04:59 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
They look home made. Home made ones can work fine if done correctly. From the sound or your replies, I would cut out and either make a nice set or spen the 150.00 and get a good set that fits correctly.
I made mine and they fit like a glove. But my car has extensive mods done to the frame.
Old Jan 26, 2008 | 07:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Without actually seeing where they're mounted, it's hard to say how good they are. SFC even in a stock third gen should be installed. I wouldn't remove them just because they're home made. My car has home made SFC
Old Jan 26, 2008 | 08:06 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
that looks alot like what i did to my car. i used 2"x2" mild steel square tubing and cut into the floor board as well as into the rear subfram, knotched it all out and welded it all up and to the front. mine are more into the floor board which is better and all the aftermarkets bc it reinforces it alil more. but i have the same space between the floor and the tubing, but for only about a 1-1.5ft. it starts to cut into the floor right where the floor board starts to flow in the downward angle.
yours dont do that so im not really sure what he did. it looks like he welded in a bar in the front on the left side of the pic but u cut it off when it started. thats what i need to do for more reinforcement but i can tell that ur gona rip them off anyway. u can def do better. its just more work to do it my way but its worth more in the end if u do it right
Old Jan 27, 2008 | 10:51 PM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
did the cat come with the car? is there any peformance gain?? lol just saw it in the background made me chuckle.
Old Jan 28, 2008 | 10:30 PM
Car: 87 TA clone
hahaha, bet that sucka purrrrrs
Old Jan 28, 2008 | 10:42 PM
TurboM3's Avatar
Yeah as you can see thats my new catback I'm working on.
Old Feb 3, 2008 | 07:59 PM
solara's Avatar
Hi new to the forums. I have recently been researching sfc and there are a lot of different styles. Any Canadians out there?? Where can I get afforable subframe conn. in Canada or Shipped. By affordable lets look. Spohn; pipe multiple piece $318.50 U.S. shipped OR Competition engineering by
Moroso; 2" square tube one piece (per side) $104.07 can. + tax (these will affect ground clearance and exhaust!) Somewhere in the middle. Better yet , anyone with good pics and a cost estimate of diy?
Old Feb 4, 2008 | 12:35 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Get the Spohn over the Moroso. The ground clearance and exhaust clearance lost isn't worth it, IMO. And some of them you have to modify the floor pan.
Ghettobird52
Jul 5, 2024 11:18 PM
86IROC112
Apr 9, 2016 10:20 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
