PA racing k member and a arms bolt specs
Old Feb 10, 2008 | 04:37 PM
Duke901's Avatar
Car: 89 Formula
On my k member and a arms, what should the bolts be torqued to. I think the a arm bolts are 68 ft pounds. Iam not to sure what the 6 k member bolts are supposed to be at.
Old Feb 10, 2008 | 06:20 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: PA racing k member and a arms bolt specs
Those bolts are 12mm x 1.75 10.9 hardness. to properly stretch them you need to go 84 ft lbs.
Old Feb 10, 2008 | 06:30 PM
Duke901's Avatar
Car: 89 Formula
so the 6 bolts that hold the k member, should be torqued to 84ft lbs
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
Nov 16, 2015 01:13 PM
355tpipickup
Aug 25, 2015 12:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
