4th gen wheels on 3rd gens
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
i was told 4th gen wheels wont fit a 3rd gen but ive seen a 4th gen bird that has 3rd gen wheels iroc wheels on it and seen a 3rd gen on here with 4th gen wheels on it so obviously its possible but how?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 4th gen wheels on 3rd gens
The 4th gen wheels fit on the rear just fine - it's the fronts that have a problem - the backspacing is off and you have to put in wheel spacers in the front to get the wheels out of the wells and keep from rubbing on the suspension components.
4th gen wheels won't fit on the rear of these cars, just like they won't fit on the front; they hit the inside of the wheel wells.
The 4th gen rear is about 1-5/8" longer on each side. Given the difference in the width of the wheels and all that, 1¾" spacers are what people commonly use on both front and rear.
Car: 1992 RS
Engine: Carbed 350
I forgot, I have a 4th gen rear!
You're right - 4th gen wheels need sapcers all around!
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
My friend got ZR1 rims on his 4th gen. I plan on buying his rear end in a few months [3.42 gears from his 2001 trans am]
Should I just buy his old rims too and put some slicks on them to use at the track or when I wanna go fast?
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Car: 1987 Z28 Camaro
Engine: LB9 V8 305-cid
Transmission: 4 speed automatic - 700r4
Axle/Gears: stock - 2.73 rear end
I used 2" spacers so that I could put the 2001 Corvette rims on my 87" Z28, as you can see in the picture below of my Camaro.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I had to use 2 1/4" spacer to get my ZR1s on the front. It depends on the backspacing of the wheels you have, not what I have or somebody else has. Once you have your wheels, measure the backspacing, the difference between that and your factory wheel backspacing, will be the size spacer you need.
www.skulte.com is a great place. The guy is a member here, he is super helpful.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Omega
Oct 1, 2015 02:20 PM
