Offset to Back Spacing?
Old Feb 20, 2008 | 10:11 AM
Stephen's Avatar
Car: 87 GTA
If I understood it correctly (read the sticky already)....
I rounded the #s off.......
The wheels I'm looking at...
18" x 8"-40mm offset=5.5" Back Spacing?
or
18" x 9"-45mm offset=6.25" Back Spacing?
Is that correct? I was wanting the 9" ones, but 6.25" is too much BS. 8" BS just isn't worth buying. I'd go wider than 9", but that's what's available, in the design I want.
Old Feb 20, 2008 | 10:20 AM
Stephen's Avatar
Car: 87 GTA
Re: Offset to Back Spacing?
Oh yeah....
In the sticky....
shouldn't 0 offset be at a wheel centerline? Meaning for a 10" wheel, 5" is 0 offset? But the table is showing 5.5" for a 10" rim. Why is there no 0 for 8.5" width?
Old Feb 20, 2008 | 11:46 AM
Guest
Guest
Posts: n/a
There's approximately a 1/2" lip beyond the wheel width on each side. So your 10" rim is actually ~11" wide edge to edge. That puts the wheel centerline at 5.5" from the edge of the rim where the backspacing is measured from.
8.5+.5+.5=9.5/2=4.75
No 4.75 on that table.
Oh and while we're at it, the tire bulge past the rim lip varies depending on the tire itself. Its going to fall between 1/4" and up to 3/4" for most of what people here will use as far as street tires go. So you should add that to your backspacing or the tire will rub... but the rim wont.
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
neekolzun
Aug 24, 2015 04:59 PM
ezobens
Aug 19, 2015 10:29 PM
Randomtask2
Aug 13, 2015 01:57 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
