Wills 18"s fit on my '83 z28?
Old Feb 29, 2008 | 10:55 AM
CamaroLover09's Avatar
Car: 1983 Z28
Engine: 305 LU5 converted to carb
Transmission: built/updated 700r4
Axle/Gears: Open 3.23
I've been looking into buying a set of American Racing IROC replicas for my camaro and I wasn't sure if they would fit. The websites that I've been looking at don't offer info for anything older than '85. Since my Z came with 15" wheels I wasn't sure if the oversized 18"s will fit. If they won't, will 17"s work?
Also will I need any spacers or anything to make them work?
Old Feb 29, 2008 | 07:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wills 18"s fit on my '83 z28?
what width are you looking at? if you can buy the wheel with the correct backspacing/offset, then you dont need spacers. You can bolt on any sized wheel that will fit in the wells, many many people, myself included run 18's, there are even some 19 and 20" wheeled cars on this site that look just fine and the wheels fit no problems.
Just remember bolt patterns is 5x4.75
Old Feb 29, 2008 | 08:36 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Both the AR IROC Chrome 7 x 18" and 8 x 18" will bolt on just fine without any spacer required and look great.
Go with the 8" wide rim and a 245 40 18 tire. It will match your old tire height perfectly so your speedo won't be out.
Good luck.
Old Feb 29, 2008 | 08:48 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Do they make this in a 17 version?
Old Mar 5, 2008 | 12:02 AM
Car: 1983 Z28
I've looked and haven't found them in 17" but I think I remember someone commenting on 17" IROC replicas. I'd rather have the 18s anyways so it works for me.
Thanks for the help guys.
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
matthew911
Aug 12, 2015 09:38 AM
