to low?
Old Mar 6, 2008 | 02:35 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
to low?
ive been workin on my car for two years and finally got the thing runnin. i have a new suspension kit on it with 2 inches of drop. im worried this is to much drop. i should have thought of this before but am i gonna have any problems with clearance besides the air dam?
Old Mar 6, 2008 | 03:31 PM
SheldonZ28's Avatar
Car: 89 IROC/05 RX8
Engine: LS1/LS1
Transmission: T56/T56
Axle/Gears: 3.42 GM/3.55 8.8
Re: to low?
My car is lowered 2" now. At stock height it hit off alot, can only imagine what it will be like now.
Ill be lovin every minute of it!
Old Mar 6, 2008 | 05:47 PM
liteumup387's Avatar
Car: 1982
Transmission: 350
Re: to low?
had my old car lowered 2" it looks nice and isnt that bad to drive just have to be careful going in and out of parking lots the only time i saw any kind of a real problem was when i pulled it into work and tried to get it over the lifts so if you dont work in a shop and you go and get tires put on it tell them to be careful or they'll rip some s h i t off lol
Old Mar 6, 2008 | 06:51 PM
gta87transam's Avatar
Re: to low?
how hard was it to lower your cars? and how carefull do you have to be now?
Old Mar 7, 2008 | 08:56 AM
rce2win's Avatar
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
Re: to low?
Lowering these cars is a piece of cake. The struts/shocks are seperate from the springs so there are no special tools required...aka: spring compressor.
It's all pretty self explainatory when you look at it and can be done with common hand tools.
Old Mar 10, 2008 | 03:04 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: to low?
so there should be no real issues. what about with 3 inch cat back exhaust. im also lookin at sub frame connectors and some of them stick out pretty far will there be an issue there
Old Mar 12, 2008 | 01:47 AM
86irocterror's Avatar
Re: to low?
lowering the 3rd gen is simple and easy in the rear. the front is a pain in the . a spring compressor and alot of swearing is how you do the front. when i was younger my cousin showed me what a spring under a load letting loose can do....to this day i fear any spring under a load, even on a compressor...lol. there is alot of energy in a loaded spring.
Old Mar 12, 2008 | 02:00 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
Re: to low?
haha thats exatly how i did my front springs.
Old Apr 2, 2008 | 03:02 PM
rocco 87's Avatar
Car: 87' Iroc Z-28
Engine: 5.0
Re: to low?
my front was easy. then again every single part under the car was removed at one point. so i set the springs in and bolted the a arms up with new bushings and went on from there.
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
