Coil Springs going??
Old Mar 25, 2008 | 02:28 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
replaced sway bar links and new struts
car still leans on the driver side a lil bit its only noticeable if u look from a distance
what do u think time for new springs?
Old Mar 25, 2008 | 03:10 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Coil Springs going??
wouldn't hurt, sounds like thats the last thing back there unless the bushings back there on the LCA and panard are shot...just a couple thuoghts to kick around. Might be time for a complete overhaul.
Old Mar 25, 2008 | 06:08 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i just added some coil boosters they didnt help i still notice the droop , could i of baught a weak strut ?? , i baught gabriel ultras
Old Mar 25, 2008 | 06:56 PM
84redta's Avatar
likely? no. possible? anything is. Did the car sag on the driver side before you replaced the shocks? Anything look out of the ordinary while you were down there?
Old Mar 26, 2008 | 12:14 AM
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
your cars frame is probably tweaked. Think about it, a limp noodle frame and even a decently torqy motor will create twist in the frame over years of abuse. I dont think ive seen too many level third gens. If they had installed SFCs from the factory I think this problem would have been avoided.
Believe me, stop wasting a bunch of money trying to lvl it out. Get a coil over kit or ground control kit (cheaper) and adjust the height to get it as close to lvl as you can for cosmetic purposes.
Old Mar 26, 2008 | 09:48 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Uh no......... Replace the old worn out springs first with some $50 moogs. If it still doesn't sit level (more than a 1/2 inch difference side to side) take it to a body shop with a modern frame machine and have them check the car for straightness. If it's off, have them straighten it and weld in a set of perimeter mounted SFC's at the same time. Don't worry about the shocks, it should sit the same without them installed anyway.
Old Mar 26, 2008 | 10:13 AM
Car: 1989 GTA
Uh yes...I doubt he has the money to afford frame straightening as most ppl don't. However, if its simply for cosmetic purposes and you would like to have the car sit fairly lvl then adjusting the spring height is pretty much the only other way of doing it besides frame straightening. Its still possible that you just have a spring sagging so do what you want and check into that first if its not breaking your wallet. A motorcycle frame straightening is well over $500...
Old Mar 26, 2008 | 12:40 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Well, if you wanted to rig it, I suppose that's one way to do it......
Old Mar 26, 2008 | 03:57 PM
mike_c's Avatar
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
How much does frame straightening for a car cost? I was thinking about having that done to mine before I had my SFC's welded on.
Old Mar 26, 2008 | 07:16 PM
Car: 1989 GTA
you need to find a shop that will do an estimate...i hear some will do it for free. Ive read some say anywhere from $2000+. You want to have a very reputable shop doing it using the highest quality equipment possible so get ready to spend the dough.
Im in college right now and dont make enough money a year to afford it. Im pretty definate that my frame is tweaked as it has been hit twice that i know about. When i have a career and hopefully a $60,000 dollar a year salary god willing then I will pay the money to have it straightened and then once it is, I will still already have a ground control setup underneath the car and will have a full out race suspension under a properly lvled car.
Old Mar 27, 2008 | 01:07 AM
Car: 1985 TransAm
Engine: 5.0L TPI
well u guys were right about the strut i replaced it and no change , theres about 1/2 in diffrence between the psg and dvr side , also if this helps narrow it down the dvr side was sitting on a flat tire for many months , and the pssgr side was on a jack for about 3 months so the dvr side has been under some stress the frame seems to be intact i dont see any bends or out of the ordnary welds , so im guessing its the spring or a worn out lca bushing i didnt think a 305 made enough torque to cause a twist
if all else fails is there a way to lower the psgr side spring to compensate for the dvr side sag??
Old Mar 27, 2008 | 08:24 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
If it's just a half inch differance it's close enough. I'd still replace the worn out springs though, you'd be surprised at how weak the old ones feel in comparison.
Old Mar 27, 2008 | 12:34 PM
Vanilla Sky's Avatar
With the car sitting like that for a while, I'd check for deformed bushings.
It's a good idea to at least have an estimate done on frame straightening. That way you know what you're working with.
87v6Bird
Jul 1, 2018 04:12 PM
timonator
Sep 17, 2015 06:57 PM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 03:05 PM
