Tubular K member with spring perches?
Car: 89 Iroc-z
Engine: 396 Stroker 625hp
Transmission: 700r4 3000 stall
I am looking to get a tubular front end from PA racing and saw they have a k-member with and with out spring perches. If I get one with the spring perches would I be able to cut out the front wheel wells that hold the factory struts?
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
Re: Tubular K member with spring perches?
No, the k member with spring perches allow you to use factory coil springs as opposed to using a coil over kit. A coilover kit mounts the coil springs directly around the struts. I don't know of a "kit" that will allow you to get rid of the struts.....
Kevin
Kevin
Car: 1992 RS Black
Engine: 305 TBI(LT1 swap soon)
Transmission: T5 (T56 for LT1 swap)
Axle/Gears: 4.10
Basically what Kevin said
but it also depends on what your doing/using the car for. If you get a tubular K member without spring perches and run coil overs may be better for racing or drag. I have a tubular K member from sphoon performance with spring perches. I going to run race springs and kyb agx's(bolt in factory locations).
but it also depends on what your doing/using the car for. If you get a tubular K member without spring perches and run coil overs may be better for racing or drag. I have a tubular K member from sphoon performance with spring perches. I going to run race springs and kyb agx's(bolt in factory locations). Thread
Linson
Sep 21, 2015 01:08 PM
