help suspension going?
Old Apr 15, 2008 | 11:20 PM
Rva's Avatar
Rva
Car: 1984 z28 camaro
when im just riding regular and i hit a bump or somthing it sounds like someone is jiggling change or somthing it just sounds like somthing is loose in my suspension, anyone know what this is? its scarin me lol
Old Apr 16, 2008 | 05:22 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: help suspension going?
If the car's stock, then the suspension parts are 20+ years old. Could be anything. Perhaps time has come for some upgrades.
JamesC
Old Apr 16, 2008 | 12:37 PM
Rva's Avatar
Rva
yea it is stock..... i guess it is time for upgrades i just dont know what to get.
Old Apr 16, 2008 | 12:49 PM
JamesC's Avatar
Start with decent struts and shocks (maybe springs), then start asking questions and reading the advice given in this forum.
JamesC
Old Apr 16, 2008 | 01:34 PM
jstuart83's Avatar
the noise you here is the sway bar links the rubber will come apart and allow the washers to hit together like tamborings i know this from experence that is most likely your problem
Old Apr 16, 2008 | 04:19 PM
Rva's Avatar
Rva
so how do i fixx that
Old Apr 17, 2008 | 06:58 AM
BlackBetty1990's Avatar
Car: 1990 Camaro RS
Engine: 315, converted to carb.
Transmission: TH-700R4.
Axle/Gears: 3.73, detroit truetrac.
It's the sway bar bushings, most likely. While looking under the rear end of your Camaro, have someone push the rear a little. (Maybe bump it with their hip a couple of times.) When the car's moving from side to side, if the sway bar bushings are jumping and moving a little in place (you'll hear it), then that's your problem. Easy fix. They come less than ten bucks a piece, I believe.
Old Apr 17, 2008 | 08:48 AM
Rva's Avatar
Rva
thanks
Old Apr 17, 2008 | 09:10 AM
jstuart83's Avatar
if you replace the front you need to do the back as well you can get by cheap and just buy the bushings and the washers and reuse the bolts but i wouldn't, also use the polyurthyne not the black rubber it has a tendcy to compress and you keep having to tighten them till you run out of thread on the bolt then they arnt really doing anything, autozone usually has the energy suspension items that are really good
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
