Installing SFC's - Can I just lift the car up on jacks?
Old May 6, 2008 | 10:57 PM
DomsIROC's Avatar
Car: 2010 SS/RS
Engine: 400 hp
Axle/Gears: Stock
I'm putting in some sfc's to help stiffin' things up.
My question is....can I put the car on the hoist and weld the sfc's in?
I thought I read somewhere that you have to lift up the car by the wheels? Why?
Can I just lift it on the hoist and weld the sfc's in?
Need to know
Dom
Old May 6, 2008 | 11:15 PM
badazz84camaro's Avatar
Re: Installing SFC's - Can I just lift the car up on jacks?
you need to have the weight of the car on the suspension or else the car will be flexed and/or twisted and when you put the sfc's in it will stay that way, so you need a drive on rack, jack stands up the front control arms and the rear axle, or use drive on ramps. but the car needs to be at ride height and the weight of the car on the suspension
Old May 6, 2008 | 11:23 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
As Badazz84 wrote. You do need the weight of the car on the wheels. Here is a thread with some info on it. Use the Search feature and you'll get more info. It has been covered more then once.
https://www.thirdgen.org/forums/susp...-bolt-sfc.html
B_Dubya
Aug 26, 2015 05:09 PM
mizz0313
Aug 12, 2015 06:45 AM
bryan623
Aug 10, 2015 11:33 AM
anesthes
Aug 8, 2015 09:37 PM
Amillionoh7
Aug 7, 2015 01:24 PM
