4th gen ws6 springs
Car: 87 IROC
Engine: 5.7 TPI
4th gen ws6 springs
will they fit in a 3rd gen? any mods needed? any onfo will be great. and yes i did a search.
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: 4th gen ws6 springs
4th and 3rd gens have some things in common. As far af I know that all of the rear suspension pars will swap but the front suspension on a 4th gen is more of a coilover setup while our struts and springs are seperate.
It would be interesting to see if anyone has adapted the 4th gen front suspension over.
Car: 87 IROC
Engine: 5.7 TPI
so are the 4ths better or the same?
WS6 was just on the T/As, formulas, and GTAs, they did not come on IROCs, correct?
Im asking b/c i was wanting to change my springs to WS6 either 3rd or 4th. or a combo of both 4th in rear and 3rd in front.
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
I'm interested as well. I'm buying a 4th gen rear end, and if the parts are better I"ll take the suspension too. The car is a 95 Firebird Formula, with the LT1 and the 4L60. My car is a 91 RS, 305 TBI with a WCT5. What parts should I grab?
thanks,
Max
thanks,
Max
Car: 89 V6 Camaro
Engine: 2.8
4th gen front springs are way different. The front suspension is not even close to being the same. No they will not work for the front. The rear suspension in 3rd and 4th gens is pretty much the same.
Car: 1982 Z28
Engine: LC9
Transmission: AR5
Pat
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
In my opinion... stick with 3rd gen rear springs. You can use EVERYTHING else from the 4th gen though. Even all the hardware. You wont see any amount of improvement to justify swapping to 4th gen rear springs..again...in my opinion.
And as everyone else said...no go on the front stuff. Nothing will swap.
J.
J.
ambainb
Apr 25, 2016 09:21 PM
