junk steering box
Old May 14, 2008 | 04:48 PM
chevyrules85's Avatar
Car: 85 camaro
Axle/Gears: 342
junk steering box
just like the post says, my steering box is junk, and im just wondering what options there are for me, ive been looking at a manual one from an 82 s10, would it work? not sure if i wanna go manual or not, what should i do?
Old May 15, 2008 | 05:07 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
Re: junk steering box
The manual s-10 box will work fine, just remember your ratio's change to make turning easier.
Old May 15, 2008 | 07:07 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Get one from a 84+ S10. It will have the 4 bolt top cover and will be a direct bolt in. Although the pitman arm will work, you should use the third gen pitman arm because it's a slightly different length. The early steering boxes have 3 bolts on the top cover and take a bit more to get them to bolt in.
The S10 manual steering box is 7 turns from stop to stop.
Old May 15, 2008 | 07:27 PM
SteelTownMadDog's Avatar
...and I thought my 2.5 stop to stop was bad.
Old May 16, 2008 | 08:16 AM
vette gator's Avatar
Car: 85 Z28
I paid about $225 for a rebuilt power steering box from Carquest. No problems so far.
Old May 16, 2008 | 08:54 AM
I just replaced mine a couple weeks ago with a rebuilt unit from Rockauto.com for $150.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Amillionoh7
Sep 11, 2015 11:36 AM
SG91camaro
Sep 5, 2015 10:27 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
