36mm (solid & hollow) sway bars questions
Old May 14, 2008 | 11:14 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i have both solid and a hollow 36mm sway bar iv had them for sometime now
I was wounding why GM offered 2 of the same sized bars but in hollow or solid? also what cars got what "solid or hollow" and what one is more rare then the other, is there any advantages? the only one i can see is the hollow bar is lighter only by a very small magian
Old May 14, 2008 | 11:30 PM
87 formy's Avatar
Car: 87 formula
Engine: 5.0 TPI
Re: 36mm (solid & hollow) sway bars questions
I don't think GM made a solid 36mm bar for these cars. As far as I know WS6 firebirds were the only cars to get the hollow 36. Also, the solid should be considerably heavier than the hollow.
Old May 15, 2008 | 05:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[QUOTE=87 formy;3755617]I don't think GM made a solid 36mm bar for these cars. As far as I know WS6 firebirds were the only cars to get the hollow 36. Also, the solid should be considerably heavier than the hollow.[/QUOTE
No solid 36 that I know of. Some Firebirds (etc.), 86-92, and some Camaros, 89-92, were equipped with the hollow 36, solid 24 combo.
JamesC
Old May 15, 2008 | 04:18 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Cars with the 1LE (camaro) or WS6 (firebird) performance packages were the only vehicles equiped with the 36mm hollow front and 24mm solid rear sway bars. GM never sold a 36mm solid bar. Not to sound like an ***, but you either you messed up the measurement, the hole on the bar is filled with dirt to make it look like a solid bar, or that bar is an aftermarket piece with the logo taken off. More than likely it is an aftermarket bar and will be much stiffer then the stock bar. If you plan to install it, just be aware that it may be too large (stiff) and make the car oversteer.
Old May 18, 2008 | 11:44 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
I'd bet you have a hollow 36mm and a solid 34mm, they look virtually identical in size. You need a caliper to measure it properly.
Old May 18, 2008 | 01:40 PM
eddie jr's Avatar
Actually, it is the other way around.....a larger/stiffer front bar will result in understeer.
A larger rear bar (or smaller front bar) will result in oversteer.
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
deracer
Apr 11, 2016 12:04 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
