Motor mounts in correct spot?
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
This might be a stupid question, but did I put the motor mounts back on the K-member in the right spot? It's been a while since it was on the car and had an engine there, but it seemed odd to have that one tab hanging off the front edge. I checked several variations of how the mounts might fit, and only found one way that the bolt holes line up.
Hardware is 7/16" grade 8 for the mount to K-member bolts and 1/2" for the bracket to mount bolts. Mount material is Prothane poly.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Re: Motor mounts in correct spot?
Ya you have them in the right spot. Its normal for that tab to hang off the front edge.
Engine: LG4 305 V8
Thanks! As soon as the engine compartment gets some paint, it is going back in.
![burnout](https://www.thirdgen.org/forums/images/smilies/burnout.gif)
NBrehm
08-05-2015 07:57 PM
