Spohn Strut Mount and LS1 brake master cylinder
Old Jun 15, 2008 | 04:13 PM
Firebat's Avatar
If I put my LS1 master cylinder on and if I put the Spohn strut tower mount on, there is about a 1/8" to 1/4" gap inbetween them. Thats if I put the Spohn part in the same spot as the stock one was. This is because the container part LS1 mc sits lower and the Spohn strut mount is an inch taller. If the mount had to move inward it would hit the white jug container part of the master cylinder.
Anyone else had this problem? I need an alignment so do you predict the strut mounts will have to be moved toward or away from the engine? I'm putting in the eibach pro kit and new struts and wider rims. If they move outward then I'm ok.
I'm just debating if I should put the stock master cylinder back in.
Old Jun 16, 2008 | 06:38 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: Spohn Strut Mount and LS1 brake master cylinder
I saw the same issue happening.. I was concerned before I even bought the strut mounts. I talked to steve about it, and he built me set of strut hats that were alittle taller than stock, but not as tall as his production pieces.
The result was the solid mounts, and plenty of room with the LS1 master.
Here is a picture of my stock mount, moved inward as far as possible, with the LS1 master. Its obvious the taller mounts would hit. I knew I wouldnt have to have the mounts moved that far in...but just in case, I didnt watn to chance it.
Now here are the new spohn ones...again moved completely inward as far as they'll go.
Just another after the alignment was finalized.
So, since you already have yours, Ill just say.... No you arent alone in thinking it will hit. But you also might be ok depending where your strut mount ends up after alignment.
J.
Old Jun 16, 2008 | 07:29 PM
Firebat's Avatar
Yeah thats exactly whats going on. I put the stock M.C. back in and its got plenty of clearance. I'm just going to have to see what happens after the alignment.
Old Jun 16, 2008 | 08:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i dont have any clearance issues with mine, when i get the car back i can measure/take pic
Old Jun 17, 2008 | 11:34 AM
Orinackra's Avatar
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
so did you end up having a problem with that? I was considering a setup similar to yours, and I already know my adjustment is pretty far in.
Old Jun 17, 2008 | 05:33 PM
Firebat's Avatar
If you are talking to me, I'm not getting an alignment til my struts show up and also until I get all the other parts installed. Its going to be a few weeks yet the way things are going.
Old Jun 18, 2008 | 11:05 PM
Orinackra's Avatar
yeah, I was talking to you. You should let me know how that works out so I dont waste my money on the ls1 master if it wont work. My stuff isnt going on till my car gets parked come fall, so I'm not in a hurry to find out.
Old Jun 21, 2008 | 04:57 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
im runnin a stock disc brake master cyl and booster, and with the spohn mounts its real close.
bet i have barely an 1/8".
all depends on the car, im sure.
Old Jul 14, 2008 | 08:41 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Here is my LS1 MC with Spohn strut mounts, fits just fine. BTW, I have the Prokit as well.
Old Jul 15, 2008 | 06:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
sorry i never got a pic, but i can move the strut tower through its complete range of motion and never hit the master, you will be fine.
Frozer!!!
Jan 19, 2024 04:55 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
