Front tie rod to tie rod distance please?
Old Jun 22, 2008 | 10:19 PM
1320jon's Avatar
Car: 87 iroc
Engine: 402 twin turbo lsx
Transmission: th400
Axle/Gears: 9" 40 spline MW, with 3.25 gears
I need a tap measure from the tierod ball joint to the other tierod ball joint. I know it varies, but Im dong a rack conversion and didnt measure before I took it apart. I have a rack at approx 49 inches with some adjustament in it.
Old Jun 23, 2008 | 07:53 PM
Guest
Guest
Posts: n/a
Re: Front tie rod to tie rod distance please?
I do not have my car accessable otherwise I would run out, measure it and help you Bud. Someone must be able to quickly measure that and help you......Anyone?
I take it you probably have the car off the ground and the front wheels off it also- if thats the case you can not just use some flat material for some makeshift toe plates against the outside tire sidewalls.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Ghettobird52
Apr 21, 2020 08:44 PM
zayne0
Aug 24, 2015 07:22 PM
