Clunk on take off
Old Jul 1, 2008 | 08:54 PM
BuiltZ28's Avatar
Clunk on take off
My rear suspension is fairly stock. Stock torque arm with a poly mount, stock trans mount, a set of those dropzone springs that were all over a couple years ago I think they were 2 inch drop.
Coming out of the hole with the mildest amount of throttle you can feel a thump somewhere in the rear suspension. It almost feels like the torque arem smacking the floor board near the back of the console or so. There is no evidence in the floor boards of this actually happening.
The U-Joint is fine.
I know fairly little about suspension.
Is this mabey a problem with the control arm angle and I need lower control arm reolcation brackets?
Help!
Old Jul 2, 2008 | 06:19 AM
ncgator's Avatar
Car: '89 Trans Am
Axle/Gears: 9 bolt 3.23 posi disks
Re: Clunk on take off
Torque arm bushing.
Old Jul 2, 2008 | 10:18 AM
85SilverIroc-Z's Avatar
could it also be the transmission mount.. I know you said.. it clunks with a mildest amount of peddle....
I had an 86 Iroc.. and it clunked also...
hope you find out what it is......
and its not overly expensive to repair~
Old Jul 2, 2008 | 10:51 AM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
my berli does this as well, i think on mine it's the torque arm slipping between the 2 pieces of the mount but haven't torn it down to see yet
Old Jul 2, 2008 | 11:21 AM
91_z28_guy's Avatar
Car: 91 CAMARO Z28
Engine: 5.8L TPI 355 L98
Yep i had the same problem with my z28. Clunking on take off. It was the trans mount. Cost me about $10 and 5 mins worth of work and the problem was fixed. You can check it out by starting the car and have someone stand on the side of your car while the hoods up and lay on the brakes and hit the gas and if you see the motor torque real bad then 90% sure thats your prob.
Old Jul 2, 2008 | 04:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
most likely the trans mount.
F-body driver
Mar 6, 2023 11:44 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
BlackBoulder
Aug 11, 2015 11:15 PM
