Swaybar mounting parts help!!
Old Jul 11, 2008 | 06:39 PM
bigmacnz's Avatar
My 82 TA is having a groundup rebuild and my mechanic said im missing 2 small peices that do with mounting the swaybar to the diff.I dont have a pic yet but they fit in the palm of your hand,are rectangular and are open on one side.The diff and swaybar are from an 88 GTA
Does anyone know what im talking about?
Thanks,
Fred/NZ
Old Jul 11, 2008 | 07:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Swaybar mounting parts help!!
You can get new poly endlinks and bushings from Energy Suspension, they'll have just about everything you could need to mount it.
Old Jul 11, 2008 | 08:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
http://www.spohn.net/shop/1982-1992-...ation-Kit.html
something like that? its a aftermarket setup, but i dont think you will find a stock setup new. Maybe ebay?
Old Jul 11, 2008 | 08:52 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Dealer, NAPA, Autozone, ect, ect should have that sorta stuff. most of the mounting hardware is the same in a lot of GMs lineup. And it's pretty cheap.
If you get that kit from Spohn, don't forget to order the bushings too, they aren't included with the kit.
Old Jul 12, 2008 | 08:16 AM
bigmacnz's Avatar
The bits i need are the mounts that the u-bolt connects through to the sway bar bushings on both sides as circled in the pic.
Old Jul 12, 2008 | 10:33 AM
572_Rat's Avatar
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I will check what is left, if I have the brackets you can have them, just pay for shipping
Old Jul 12, 2008 | 04:00 PM
572_Rat's Avatar
I have both the brackets if you want them
Old Jul 12, 2008 | 06:34 PM
bigmacnz's Avatar
Yes please can i pay for them by paypal?
Would you also know where i can find sway bar bushings.I tried summit but they charge a $24.95 handling fee plus shipping which i dont think is right.
I need 34mm for the front and 22mm for the rear.
Thanks.
Old Jul 12, 2008 | 06:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by bigmacnz
YWould you also know where i can find sway bar bushings.
http://www.spohn.net/shop/1982-1992-...s-Accessories/
JamesC
Old Jul 13, 2008 | 01:33 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I include those brackets with the greasable rear sway bar bushing kit.
Lon
Old Jul 13, 2008 | 01:43 AM
bigmacnz's Avatar
Do you do that in a 34mm version and do you have 22mm for the front?
Old Jul 13, 2008 | 08:24 AM
lonsal's Avatar
http://www.top-downsolutions.com/pro...products_id=43
http://www.top-downsolutions.com/pro...products_id=67
Please measure your rear sway bar again. I'm not aware of a factory 22mm rear sway bar. 24mm, 23mm, 21mm yes.
Lon
Old Jul 13, 2008 | 08:34 AM
DM91RS's Avatar
Car: 91 RS
Lon....you still have 36mm fronts?
Thanks...DM
Old Jul 13, 2008 | 10:54 PM
lonsal's Avatar
Yes.
Lon
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
