Spohn Driveshaft Loop Install
Old Jul 14, 2008 | 03:00 PM
thewolf's Avatar
Car: 1984 Pontiac Trans Am
Engine: LG4 305 V8
Axle/Gears: 10-bolt LSD
I searched around and couldn't find a precise answer to my question. I ordered a driveshaft safety loop from Spohn a while back for my 1984 T/A. The transmission crossmember has a single, centrally located 10mm slot. The Spohn loop requires a two bolt poly transmission mount, and I have one from Prothane ready to go. Can you see any issues with me doing the following:
- Mill two 7/16" slots into the crossmember, 1.5" apart, centered on the existing slot
- Weld a small strip of 1/8" material into the center slot, and grind flat
- Bolt the loop to the crossmember and Prothane mount from the bottom
I was unsure if later third gens came with a two slot crossmember. Grabbing one of those would probably be less work if they exist. The transmission is a 700R4, if it matters.
Old Jul 14, 2008 | 03:17 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Re: Spohn Driveshaft Loop Install
Sounds like a good plan to me.
Old Jul 14, 2008 | 11:31 PM
thewolf's Avatar
Engine: LG4 305 V8
Thanks! Wasn't sure if I was going the long way around on that one.
Frozer!!!
Jan 19, 2024 04:55 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
