What Do I Need To Replace?
Old Jul 20, 2008 | 01:21 PM
NBMIROC's Avatar
Car: 1989 IROC-Z Camaro
Engine: 5.7
Ok, my IROC isn't running so i can't tell you how it drives, but what I do know is that it will bounce like crazy. Push down on either the front end or the rear with relatively little force and you can go down pretty far and it bounces right back up. Very worn.
So this would be the springs right? What else?
Sorry to be a n00b, been out of the third gen/old car game for awhile.
Old Jul 21, 2008 | 04:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: What Do I Need To Replace?
That's because your shocks are shot. New ones will fix that. Springs wouldn't hurt either, but a good set of shocks will help more than about any other single thing you can do.Read through this. It'll tell you what you need to know.
Old Jul 21, 2008 | 08:02 PM
spray004's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: BTO 700R4
Axle/Gears: 4th gen 3.73
Put new shocks on the car.
Old Jul 22, 2008 | 07:42 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Sounds like the springs are just as much at fault.......
"Push down on either the front end or the rear with relatively little force and you can go down pretty far"
Anyone still riding on worn out stock springs should have replaced them 10 years ago.
Old Jul 23, 2008 | 05:54 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Good point.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
