Can the pinion yoke smack into the top of the tunnel?
Old Jul 21, 2008 | 02:25 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Err, I guess what I meant was, how hard is it to make the pinion yoke smack the top of the tunnel? ie, what the heck did the previous owners do to her??
My red car has this damage (pretty good little dent coming into the car) on the body of the car right in between the two rear seats. It's right above the rear yoke and when you look from the bottom it looks like the car bottomed out so bad the yoke hit the body quite hard, appears to have happened at speed as well. It made cracks and there is a hole big enough to fit 4 fingers through, like I said it appears to have hit hard.
Anybody ever see this before?
Sorry I don't have pics right now.
Old Jul 21, 2008 | 09:51 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can the pinion yoke smack into the top of the tunnel?
Probably tried to drive it without the torque arm.
Old Jul 21, 2008 | 12:32 PM
Guest
Guest
Posts: n/a
Thats VERY common with lowered cars. It just clearances itself. I hammered mine out carefullywith a real lightweight body mallet and then glassed in the void from the topside under the rear seats. painted it with epoxy paint and you can no longer tell from the bottom side a few years later with natural weathering that it was even damaged and altered.
Old Jul 21, 2008 | 01:05 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
A broken tranny mount can also cause this.
Old Jul 21, 2008 | 04:11 PM
Guest
Guest
Posts: n/a
Acccidental miss on your part. He listed pinion yoke, not the tranny yoke. But yes, a broken trans mount would make the tranny yoke come upward.
Old Jul 21, 2008 | 07:56 PM
krisb410's Avatar
Whoops, I read that one wrong, sorry guys.
Old Jul 26, 2008 | 10:48 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Old Jul 27, 2008 | 11:50 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I'm still wondering how that could have happened if the torque arm was on there. I think you might be right as far as trying to drive it or pull it maybe without the torque arm installed.
Maybe they wanted to see what it was like to drive without springs in the rear and without the torque arm at the same time. The shape of it looks like the pinion was still pretty much parallel to the body. Is there any way to get the car that low on the rear?
Old Jul 27, 2008 | 12:18 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
no tq arm or broken tranny mount will let it touch really easy... shenanigans... i cant read hahah... wow
Old Jul 27, 2008 | 03:33 PM
kanexpl's Avatar
Car: 94 C1500
Engine: 353 TBI
Axle/Gears: 4.10
Broken rear ujoint caused the drive shaft to hit. The impact looks round like the drive shaft was rotating. Do you see any marks on the drive shaft? It may have been replaced.
SG91camaro
Sep 5, 2015 10:27 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
