torque arm... need it?
It this thing really needed? I have been building cars for years but never a 3rd gen until now. Never had a car that has had a torque arm, seems to be in the way more than anything. i have converted to a th350 and it seems that if keeping the arm i will need to change the tail of the trans. it seem that it is there to prevent twisting of the frame, if thats the case cant i just run sub frame connectors?
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Re: torque arm... need it?
ya youll need it unless you want your car to twist like a prezel... ive seen some major damage done to a 3rd gen without one on.. windows breaks, a pillars twist... its not pretty nor cheap to fix...
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
you definitely need it for the stock type suspension.. if you modify it, ie. ladder bar or 4link, its not needed.. most people just get aftermarket crossmember mounted torque arms from Spohn, Bmr, Umi, or Jegs..
Engine: Vortec 357
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the panhard bar keeps the rear from moving left to right, the lower control arms keep the rear centered front to back, the torque arm replaces upper control arms and prevents the rear from rotating up or down.
without the torque arm, the rear will rotate upwards during acceleration and rip the driveshaft out of the tranny and destroy the rear of the car. It will not twist the front in anyway, it will just rip the complete rear suspension out.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The torque arm is similar to a 3 link suspension. It's a required suspension component like any other suspension component. GM just happened to attach it to the transmission. Aftermarket torque arms attach to a new crossmember so it has nothing to do with the transmission or actually mounting it on the transmission.
When a car accelerates, the front of the differential wants to rotate upward as the pinion climbs the ring gear. With a leaf spring suspension, this twists the leafs and traction bars can be installed to limit how much they twist. With a factory triangulated 4-link car like an 80's G-body or a mustang, the upper and lower bars prevent the diff from rotating. Since the third gen rear suspension only has lower control arms, the torque arm adds a single point similar to a 3 link suspension to keep the diff from rotating. The only proper way to eliminate the torque arm is by changing the suspension to ladder bars or a 4-link. Ladder bar type LCA will work but are not a performance component and will not be strong enough for anything but mild street use.
Car: 1984 Z28
Engine: 406
Transmission: 350th
Axle/Gears: 373:1
Car: 2002 Z28
Just messin with you, but seriously, you need the torque arm, even the new mustangs have adopted a rear suspension that is similar to the 82-02 FBody.
Car: 1986 IROC Z
Engine: Nothing but air
Axle/Gears: Four stands
I had my car towed to the paint shop with no engine and gearbox in. Because there was no gearbox in the car I couldn't mount the torque arm. I couldn't see a problem with it until I went to look at the car at the paint shop.
The diff had rolled right up until the input shaft smashed into the floor. The wheels were pressed hard up against the back of the wheel well. The damage to the floor pan was minor but it snapped the bottom mounts off my shocks(I upgraded to Konis anyway so it wasn't too bad).
That was just from having the car winched up onto a tilt tray truck. I'd hate to see what would happen if you tried to drive with it disconnected.
Thanks everyone, I am so happy it sounds like i really dont need a torque arm after all......just kidding. I bought the replacement one from JEGS last night and its adjustable so thats cool. thanks for the info
Car: 89 Formula 350
Engine: 5.7 TPI
"even the new mustangs have adopted a rear suspension that is similar to the 82-02 FBody." I noticed that too, guess that says something for our cars!
no green
Jan 9, 2016 09:22 PM
