Most Power Someone Has Put Down On Adaptors
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Now first off I have used the search button and could not find what i was looking for. My question is how much power or how fast has someone gone on skulte adaptors or any adaptor for that matter. My Iroc currently puts down 450 at thw wheels with the TURBO LS1 but I'm about to install a Forged 370, bigger Turbo and Strange Dana 60. My new setup I'm shooting for 750HP to the wheels. Should I just get a set of 18's like drift r's for the street and some 16's or 15's for the track? This is racking my brain.
Car: 87 IROC,
Transmission: 4L80E
Re: Most Power Someone Has Put Down On Adaptors
So nothing? No one has put down alot of power on these? Makes me wonder if i want to keep adaptors...
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Grifter - That's no problem at all. I've got quite a few drag racers running our adapters w/ some serious launches, and lots of street/road race guys in the same HP ballpark as your new setup (and I run the adapters myself on the Z28tt as well). The only application I wasn't comfortable with was a mud-bog competitor running dual rockwell axles with 2000 hp on 40" tires. If you think about how the adapters are loaded - the joint is exactly the same as a factory wheel to the hub, so it'll hold just as much torque. With the 5 lugnuts torque to 85 ft-lbs, you've got about 20,000 lbs clamping force (make sure the surfaces are clean and dry - I spray/wipe down with brake clean), so none of the torque will get transferred to the studs/lugnuts. In short - your 9 inch or Dana 60 will break before the adapters. I hope this helps!
Car: 87 IROC,
Transmission: 4L80E
Thank you very much! this has been a great help. Although I think I might still get new wheels I am not in a rush any more. And if i break a Dana 60 then I will retire my car alltogether
Again thanks for the help!
Again thanks for the help! Thread
Iroc8t8
May 4, 2026 08:09 PM
1992rs/ss
Jan 31, 2025 05:10 PM
