WHAT DOES 'WS6' MEAN ??
I heard that all 'ws6' cars had posi-rear ends.. is this true,, exactly What does the 'ws6' stand for ?? Were they just options you could order, or where they required when ordering the WS6 option,???... i Don't know which catagory to post this in so I may ask the same question on other threads..
Car: '91 TA vert
Engine: turboLSx
Re: WHAT DOES 'WS6' MEAN ??
WS6 is just a code, aka RPO(Regular Production Option) code that tells the people building it on the assembly line what options they need to add to the car. Depending on the year you got different things with the WS6 RPO code; 16" wheels, limited slip diff, stiffer swaybars, etc.
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
Take a look for your RPO sticker, check under lid of Center console. You can download the decoder of this site and it will tell you all the options of you vehicle
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
WS6 is the Pontiac RPO code similar to the Camaro Z28. It's an option code but not a specific item code. If a car has the RPO code G80, it has a posi. Z28 and WS6 may or may not mean that the G80 code is included.
Somewhere in your car should be the list of the RPO codes. Camaros have it inside the center console. The RPO codes will tell you everything your car came with from the factory. A previous owner can always change things.
You may also take the VIN number to the dealer and get a copy of the line ticket which will also say everything about the vehicle as it was built down the assembly line.
Car: 87 GTA
It was generally under the center console lid...the rear glove box lid, or occasionally under the rear seat carpet, if the assembly line person didn't just throw it away.
The RPO code WS6 was a suspension package of springs & swaybars.
Car: 87 Trans Am
Engine: TPI 305
Transmission: TH 700
WS6 means that you have the "performance suspension" package. As iansane told, it depends on witch year it was made. Take a look here, and scroll down to your model year. Then you see what you got!
